Question about Whirlpool RBD305PDS Electric Double Oven
After self cleaning the display is blank and door is locked
We have replaced the thermal fuse but still no display or unlocked door. What is the next step?
  • Whirlpool Master
  • 3,361 Answers
Which thermal fuse did you replace?
There are 3.
This manual will help you diagnose the oven.
Thermal fuses are explained on page 3-2.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Posted on Jul 11, 2010
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
SC302TS. Why won't oven heat?
If it's not the thermal fuse, it is often a control board failure. These boards are no longer available from the mfr but can be rebuilt at:
http://www.fixyourboard.com/boards/14-38-901.html
Often the relay boards need work too. We can rebuild these as well. Just contact us at FixYourBoard 512-355-1108
Aug 11, 2015 | Thermador Ovens
Oven door won't open after cleaning
The oven shut down before self cleaning completed without a model # this is what I can tell you the TOD thermal overload fuse opened cannot be reset if you have no display then the thermal cavity fuse opened buy a set of feeler gauges from the auto store take one go to top of door in the middle between between door and body push to left door should open.
Sep 24, 2014 | Whirlpool Ovens
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
Kitchenade
Kitchenaid is made by Whirlpool. They have had a problem with the self clean getting too hot and shutting down the control board thermal fuse. If you can access the control board. (power off) there should be a small inline thermal fuse attached to a connector usually on the far right of the control board. It is encased in a clear plastic tube. Test this for continuity. If it is bad replace this fuse and the display should come back on. They also have a thermal fuse on the back of the oven that usually goes out at the same time. If the oven and broil don't work after fixing the control board thermal fuse. then you will have to pull the oven out enough to take the back panel off and check this fuse.
Feb 09, 2014 | Ovens
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
Whirlpool RBD305PDS Electric Double Oven Logo
529 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
