Question about Inverter Delta Vfd150b43a Ac Drive Vfd B 20hp 460v
Terminels of potenchometer
I have a desal pump testing bench it is totly coputrisd but now i want manuali becase his softwer is not boot by scasi mother bord probelm and not availbel i change invertor parameters acording his catlog but not found conection 4r vareable speed controler gid me pl
    Scholar:
  • 142 Answers
You better buy a multi turn potentiometer about 4,7 - 5,1 kOhm.
Connect its ends to "+10 V" and "ACM". The Slider connect to "AVI".
The multi turn pot can make small steps of adjustment.
Hope that it will help.
Posted on Jul 12, 2010
Testimonial: "THANNKS FOR ANSWERING I WILL DO TOMAROW THANKS SO MUCH"
    New Friend:
1991 Dodge Dakota fuel pump wireing. I removed pump and tested OK- Tried switching relays (all same in relay box) Still no cycling only a slight noise then silent. Ran 12-v (spiced) to left wire of 5.
engine cranking do you have spark at the plugs and fuel injector pulse? I don't know what testing you have done? I am trying to decide if more than one issue? Did you check voltage and ground at fuel pump connector, engine cranking? Initial prime is one thing but after that, if no rpm signal, no spark--no fuel injector pulse--no fuel pump. W/o rpm signal computer won't ground the asd relay. Any applicable trouble codes?
In my opinion, you can't bench test a fuel pump, I've seen faulty fuel pumps that would run up a storm on the bench but make no pressure when in the gas tank.
May 09, 2017 | Dodge Cars & Trucks
I have a new executive 56 and it keeps surging on low speed. I had it bench tested from distributor. It doesn't have an airlock. Testing at the board doesn't show any issues. Any Ideas?
water pumps that have this indication suffer for restricted input flow of the water
if you are using a pool cleaner it could be a fault in that operation, or hose collapsing, or a problem in the filtration equipment
while you have had the pump bench tested you may have to get in the pool expert to determine the problem with the pump in operation
Aug 07, 2016 | Waterway Spa Pump Executive 56 Frame 4hp...
2002 Taurus bench tested fuel pump and motor works then connected to wire harnes it doesn't work, why?
Did you check the fuses or relays..If so check the inertia fuel shut off switch..The owners manual will show you where its located
Apr 30, 2012 | 2002 Ford Taurus
Describe your Satellite L505DGS6000 Laptop AMD Turion II dualcore M500 160" HD LCD 4GB DDR2 320 (PSLV6U01F009) PC Notebook Problem . Computer would not boot up windows. Found that HD had failed....
if boot up but slow, you have tot test memory amount and speed and temperature of cpu cooler. if your hard drive is not have 100% smart feature test result, may be slow down. it is rarely with power problem. but you can test with another AC Adapter.
Oct 04, 2017 | Toshiba Satellite L505DGS6000 Notebook
Cleaned ice machine because desale light was on , unit is cleaned and run through clean cycle buy desale light still on
make sure you press the clean button let run 10 min or so then press it again.if you dont press it the second time descale will not reset.
Aug 06, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Either the fuel pump isn't getting power, or is junk, but i would like to test before i replace the fuel pump. what i need to know is which color (pink, orange, yellow) wire is the power tot he pump.
Before you get to the pump be aware that ford has a inertia (spelling ?)switch that cuts off power to the pump if the vehicle is bumped hard or jolted.They are usually in the trunk and can be re-set by pushing the tab on it!
Aug 05, 2010 | Ford Taurus Cars & Trucks
Fuel pump clicks i have replaced the fuel pump/filter/relay
you need to be aware of the most important rule just because its new it does not mean its good . fuel pumps hum they dont click you need to remove it and bench test it its most likely stuck . i always bench test them before i install them . hope this helps .
Jul 31, 2010 | 2002 Pontiac Grand Am
A/c
both of you all prob have problems with the flappers or baffles in the rear that controls the air flow they may just need to be moved manualy becase somthing is stuck in there or the could be broken.
Jun 13, 2008 | 1999 Ford Windstar
Inverter Delta Vfd150b43a Ac Drive Vfd B  20hp 460v Logo
178 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
