Question about Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri
The cold water stop working in my shower. I have a
The cold water stop working in my shower/tub. I have a Price Pfister 17196-0100k. I only get very hot water. What can I do?
    Scholar:
  • 56 Answers
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Posted on Jul 20, 2010
Pfister hanover 808TMKK hot water stopped working why?
Sounds like the cartridge went bad Home Depot Cary's some but not all of them
Sep 04, 2014 | Price Pfister 808-TMKK Hanover Single...
3 handle shower - handles tap/ block each other
It sounds like you have the wrong handles for this faucet assembly. Did you recently purchase new handles?
Jan 17, 2013 | Price Pfister 01-81BC Savannah 3 Handle...
Set water temp
remove the handle, find the plastic disk with teeth, pull out disk and turn to left for hot, right for cold, set disk back in place, then replace the handle, repeat as necessary.
Feb 22, 2012 | Price Pfister Plumbing
My price pfister tub and shower value is only letting out hot water. cold water will not come out. This just started out of the blue. has been working fine.
remove the cartridge and replace it with a new one. They have cams and pistons inside that out of the blue the cam does not work and then you get only hot or cold water.
Best of luck Rich
Sep 06, 2011 | Price Pfister Plumbing
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri Logo
1,074 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
