Question about Sunbeam SAW10CR1FHU Thru-Wall/Window Air Conditioner
Leaking inside house , condensation or something causing liquid to leak inside house and i have to use towels to catch fluid
    Problem Solver:
  • 11 Answers
Should have a drain hole on back to drain outside it maybe pluged or unit is not leveled to outside has to have a slight tilt for water to drain out not in.
Posted on Jul 11, 2010
My nissan quest 95 is leaking water. It seems is coming from around the filter. Need help please
Dear Helen,
Which filter? You have the air filter, the oil filter, and the cabin filter.
If it is coming out near the air filter or the oil filter, I should suspect a leaking heater or radiator hose.
A pressure tester for the radiator will help you find those leaks.
If it is near the cabin filter, it should be the drain tube for the air conditioner condenser, which is normal to leak when the air conditioning is running.
Try to catch some of the water that is leaking and see which fluid it is.
Air conditioner condensation water is clear, it even looks drinkable.
Anti-freeze/coolant liquid is colored blue, green, red, or yellow, (it depends on the brand) and has a distinct sweet smell and taste. No, I am not recommending you should taste it.
God bless your efforts.
Sep 04, 2015 | Nissan Cars & Trucks
1996 toyota tercel is leaking radiator fluid
Get a paper towel and try to absorb the liquid. See if you can match the color to any fluids of the car. If its clear and has no smell its water which would be coming from condensation, a very typical non-issue.
Apr 06, 2014 | Toyota Tercel Cars & Trucks
Ac is leaking fluid into car on passenger side
If you can feel the a/c and heat but its just not blowing out of the vents like it should, more than likely you will need a new blower. Check the fuse for it first.
If the liquid is green its antifreeze and your heater core is probably leaking if its clear and looks like water it could just be condensation from the a/c.
Mar 04, 2013 | 2007 Kia Spectra EX
There is water dripping on my foot when my foot is on the gas pedal this has just started what can this be?
It could be that the drain that removes water when the a/c evaporator drips is plugged and it is backing up into the passenger compartment.
If it happens when it rains it could be a leaky windshield or water leaking in through the cabin air filter.
Jul 27, 2009 | Chevrolet TrailBlazer EXT Cars & Trucks
Leaks on inside Toyota Corrolla on the passenger side
It could be water condensing from the A/C and dripping onto the passenger rug. Check under the passenger side dashboard, above the footwell, for the drain pipe from the A/C. If it's loose the water may leak into the footwell when the A/C is running. Should be reasonably easy to fix.
Jul 11, 2009 | 2007 Toyota Corolla
I have a leak directly in under the engine block a clear liquid with a hint of black....
Do you have a/c in the truck? Just wondering if it's water from the condenser. How much is under the engine? Are any fluids going down and have to be topped off occasionally? Power steering and auto trans fluid are pink, coolant is green, so the only 2 possibilities would be engine oil or brake fluid. Post answers to above for further help.
May 03, 2009 | Chevrolet 1500 Cars & Trucks
Blue fluid leak
There is no blue fluid in a refrigerator.
Something external or a add on is causing the blue fluid.
Mar 13, 2009 | Kenmore Refrigerators
Leaking dark fluid from motor when juicing
sounds like the start of a horror movie. lol
ok dark? and no cracks or leakage from the juice container? hmm
dark .... ...its gotta be juice leaking down and mixing with the dark grease they use on the bearings.. but this is a wild guess. and i cant think of anything else unless a 100 roaches live inside the motor housing.
get it fixed when it starts to whine or smoke.
Apr 03, 2008 | Champion 2000+ Household Juice Extractor
A leak from the fridge
Without knowing a bit more about the black fluid it is hard to guess where it could come from - in a fridge there should be no black fluid and the only oils are mixed in with the refrigerant so the fridge will not be working if any noticeable amount is leaking out, as the gas will leak out as well. As you mentioned, the most likely liquid is water from inside the fridge or condensation from inside or outside that has bacteria growing causing the blackness. this sort of water may usually only be in the water tray at the back but there are many possibilities of it leaking out somewhere else - only way to check is to get the fridge running, up on four chairs or a VERY strong glass table so you can see where it is comning from. Another possibility is that there is some insect, plant or rodent factor - the moist warm space under a fridge is quite popular and they can produce their own liquids and also especially rodents cause unpredictable holes and damage all over the place. also can only be checked by looking very closely at the source of the liquid. The last possible cause i can think of is some sort of corrosion - i have not heard of this type of corrosion with a fridge, but it is quite common on steel ships - salty humidity and chemicals (cleaners/cargo etc) reacting strangely with the paint or steel are normally blamed - just think if you get too many strong cleaning products near the bottom of the fridge and look for general condition of the paint/metal underneath you should be able to see it easily if the black fluid was in any significant quantity - there would usually be a sort of rusty look to the fluid, but not always depending on the combination of chemicals present. Where you describe the fluid coming from, sounds like it could be from the door insulation - maybe leaking through the bottom hinge holes - check that nothing is leaking into the door from inside, although condensation can easily happen in the door body itself if the insulation has separated slightly from the "skin" of the door inside. Last thing to try is to investigate the fluid itself a bit more closely - get some on a piece of kitchen paper towel or a coffee filter and then wet the paper with water also just next to the fluid- the parts of the liquid should separate out a little as the water soaks through the paper and you may just see something that looks familiar. If you get no luck post back and try to describe exactly what the fluid does smell like, without trying to imagine smells like "oil" which means nothing as they are all different and in particular fridge lubricants are relatively odourless. think of things you actually know the smell of and try and describe it in those terms - if you feel brave then it may be worth tasting the liquid - just taste a tiny tiny bit on a cotton bud/Q-tip dabbed on a few different areas of your tongue and then wash your mouth out with mouthwash straight after instead of spitting or swallowing - I know it sounds dangerous and disgusting but it is the way that many professionals identify unknown substances as taste has a much more specific "database" in the brain than smell has. just be sensible. Hope this helps - post back if not - photographs may help if you have a digital camera, especially of the coffee filter test if you get round to it :) Good luck
Jun 22, 2007 | Kenmore 64802 Top Freezer Refrigerator
Sunbeam SAW10CR1FHU Thru-Wall/Window Air Conditioner Logo
304 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
