Question about Refrigerators
Taking the ffreezer door off to get into the home model pds22scrbrss
    Scholar:
  • 149 Answers
Generally theres hinges on doors one on the top and one on the bottom just remove the screws and then replace.
Posted on Apr 20, 2008
The compressor on my Kenmore chest ffreezer is really hot and sounds like It is running but not running right
first question would be is the fan condenser fan running or is it dead. if it is not running then the compressor will overheat.
May 11, 2014 | Freezers
Frig is a top ffreezer. the freezer stays very cold but bottom has no circulation.
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 24, 2011 | Whirlpool ET1MHKXM Top Freezer...
Two pulleys have come off my liftmaster 9851 garage door. how do i fix it?
Hi. The pulleys are held in place with a bolt and a nut. Go to any hardware or home depot that has garage door parts. Take another pulley off and take the missing pieces with u. J.
Aug 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
GE side by side ffreezer continues to frost over
A simple defrost may not be all that is needed. There is a piece that connects to the coils called a defrost timer or a " clixon " This is most likely the problem. Have it replaced and that should get you back in business. Hope this helps. Good luck.
Jul 09, 2009 | GE Refrigerators
2006 TOP/BOTTOM MAYTAG COMPRESSOR MAKES LOUD D RILLING LIKE NOISE
Yes it is. All the cooling is done in the freezer and air is circulated through the frig.
Eric
May 24, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Our water line is black, but the back line from teh wall is clear
no need to undo the door to replace this line, youll need to re-order a new line( it comes as a predetermined lentgh with a spout attached at end, ther is a quick disconnect under the ffreezer door and it simply pushes through fromt the spout end followin a premade opening in the door,
Jan 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice forming where ice comes out to refrigerator
I am not sure if this is the same issue or not.  the flap that closes after you have dispensed ice does not close or seal all the way.  The gasket is worn down. the result is warm air get up into icemaker and warms ice and refreezes in one block so now the dispenser gets blocked.  We had to replace the flap in the door.  bought the part at an appliance part  store (not sears) they were helpfull and looked up the part needed.  Also a sheet of ice forms on the  bottom of the freezer.  When water is dispensed a small bit drips inside freezer in back and runs down to botom of freezer slowly forming a sheet of ice.  Use a hair dryer to defrost and then you must unclog the drain in the back at the bottom of ffreezer to allow it to drian.  Once we finally unclogged the drain we have not had any problems for about 2 years.
Nov 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
