Question about Bosch Classixx WFL 2066 Front Load Washer
My classixx 1200 washer washes fine but it does not rinse , you get a noise from the draw side of the machine when the rinse light is on.and the middle compartment does not empty? I have drained the machine down and unscrewed the pump/filter door to check if anything is blocking the impeller but all seems fine there is nothing blocking it ,does anyone have any suggestions???? thanks.
Heater not working .m/c is waiting for correct water temp.
to test try a cold wash only & machine should go thro full cycle
Posted on Jul 16, 2010
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
I have a bosch classixx express 1200 washer and when its on rinse it makes such a loud noise and also when its on spin, its like a grinding noise. hope u can help.
The noise is relative to the motion and so the areas to check must be the moving parts of the washer. So shut down unit , disconnect power and check manually the movement of the motor, the rotor and the drum.
the bush can be worn out the suspension can be weak or the belt can be faulty.
your observation while the motor works is important.
Check these links below for some help :\
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Feb 15, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have a classixx 1200 WFL2463GB/12 and it keeps bolwing the fusebox in my house.My dad seems to think that it must be the element as it does not happen as soon as I turn the machine on.I then put it on...
I would suspect that it is the element, as if it were the motor, then it would not have done a rinse cycle.
Disconnect the element and try it again, if it does not blow, then this proves it is the element.
Feb 02, 2011 | Bosch Classixx WFL 2462 Front Load Washer
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Feb 26, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Classixx 1200 Washing machine won't drain & spin
The motor and motor control unit need to be replaced.
Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Bosch Classixx WFC 2465 Front Load Washer
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 6 1200 washer
Problem will be ... machine will use your hot water during the rinse cycles! So, No.
Aug 14, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
232 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
