Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
I have a motorola H350
Cant connect the bluetooth to my phone lost the pin . put 0000 but it says connection failed
  • 2 more comments
  • nbtb Apr 20, 2008
    thanks for all the help
  • caluag _m Jul 01, 2008
    i need to set up my bluetooth help me pls.
  • Anonymous Jul 21, 2008
    I got a new phone and need to program my wireless headset, unfortunalty i lost my passcode. I tried using all zeros but it didnt work.
    Thanks for the help
  • Anonymous Jan 11, 2009
    your a genius manowar1. thanks.
  • 16 Answers
Sounds like you need to do another method of connecting your phone to your unit, heres the trick..
Most phones have multiple methods of installing your headset, you can either connect it, or activate an existing connection, and last SEARCH.
If you have installed this unit already, all you need to do is ADD another device, when you find your settings for blue tooth, its as simple as TURN ON CONNECTIVITY, and your phone will find the device, if you stored it already on your phone.
Another step is to do a reboot of your headset, hold down the call button until your headset light turns on and turns colors, keep holding the button down 5-10 seconds and you will see it, then try to connect your mobile phone to your unit by SEARCHING for DEVICES in your phone settings.
Last but not least, you can search the internet for the headset, download the PDF and pray that this simple solution can assist you. Motorola's website is very user friendly and has a search engine similar to google or yahoo, register your headset while you are there, because you can get it replaced, exchanged, and have warranties with ALL new units purchased, or if you purchased a used unit from a local store, you still have a limited warranty you can use to get a new or repaired unit.
I hope this helps..
PLEASE RATE ME!
ManOwar
Posted on Aug 09, 2008
I put 0000 in for the pin but the problem was the bluetooth went off during the connection period
Posted on Apr 20, 2008
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
I lost my user manual and don't know the numerica passkey to connect this to my new phone.
To turn on Bluetooth and connect a Bluetooth hands-free headset or car kit:
  1. On the Home screen, press the Menu key.
  2. Touch Settings
  3. Touch Wireless & networks
  4. Touch Bluetooth to turn it On
  5. Touch Bluetooth settings
  6. Touch Scan for devices (make sure your headset is in pairing mode).
  7. Your phone scans for available Bluetooth devices
  8. Touch the Bluetooth device to select it
  9. Type the PIN if needed (PIN is usually 0000, or 1234)
  10. Touch the device name again to connect to it.
May 17, 2010 | Motorola Mobility H350 Wireless Headset
My bletooth h350 handsfree device needs a pass code for my phone to accecpt
All the motorola bluetooths that i have had that needed a passcode used "0000". See if that that works. Good luck!
May 28, 2009 | Motorola Mobility H350 Wireless Headset
Maual for Motorola H350 bluetooth headset
The default pin for bluetooth devices is 0000 and the manual should be on Motorola's site. I found your manual on Motorola site. http://www.motorola.com/support/v/index.jsp?vgnextoid=e780462d3080e110VgnVCM1000008806b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD click the quick start guide manual link on the right hand side to download the PDF
Jan 06, 2009 | LG VOYAGER VX10000 Cellular Phone
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
Lost H350
Within your phone you can remove the device. Enter your menu. Find connections. See bluetooth -enter, Device history-enter- select-your Motorola H350 is listed. Go to options and delete. All done. Have a nice day!
Please vote.........
Jan 16, 2008 | Motorola Mobility H350 Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
138 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
