Question about Coleman Mach 15 Air Conditioner
I have a coleman roof top a/c with no wall thermostat. can i put one on it? not sure which model i have. are thre some models which a thermostat cannot be installed on?
    Problem Solver:
  • 7 Answers
Yes, you can put a thermostat. Doesn't it have a cold/hot selector? The fan may still run when you turn it to warmer, but it limits how much the compressor kicks on and off. You will need to go to an electrical supply and tell them what you are doing, and whether or not they recommend you use a relay or wire into the one already in the unit.
Posted on Jul 11, 2010
Electric furnace coleman model # 3120A751. It won't shut off on its own. Just keeps blowing hot air any ideas?
something is wrong in the 24v. make sure no wires touching each other both behind the tstat and on the circuit board in the furnace.
and obviously r to red w to white y to yellow.....
Jan 27, 2015 | Coleman Heating & Cooling
How do I change fan motor on my Mach 1 roof top RV A/C Model 8335D8764
Try airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Nov 18, 2013 | Coleman Mach III Air Conditioner
I replaced the seal under my coleman rooftop AC unit and when I did it I tilted the AC unit on it's side while replacing the seal. After putting it back together the unit will not cool. The fan blows...
I suspect that something has shifted and is causing you trouble. If you can give me the model number off the base of roof unit, and tell me whether it's mechanical controls at ceiling or thermostat on wall would certainly help to describe proper procedure for troubleshooting. Don't give up yet, may be quite simple. First of all shut all power off to unit and go up on roof and remove the 4 screws and lift cover off. Take a look for any damage especially at top of compressor where wiring is going in. Remove the 2 nuts at top of compressor holding cap on over connections and take a look for loose or broken wires or connectors under there. If not experienced with any of this, use a pair of insulated needle nose pliers to be safe, to wiggle wires etc., otherwise please ask someone experienced with electrical.
Then if that's looking good, follow wires from compressor back to cover on side which is usually held on by a screw and remove it. You should see (if right model) some round and oval capacitors. Check to make sure none of them have shifted around and wires are touching each other or any metal around them. If you find any loose or off terminals, use pliers only and keep hands on insulated part of pliers to replace it. Let me know what you find. REMEMBER!! If your not experienced in this area, don't touch it and wait for someone who is. Capacitors store lots of voltage, even when power is off, and can be very dangerous.!!!
Jul 03, 2011 | Coleman Mach III Air Conditioner
ROOF A/C RUNS ALL THE TIME...WHY?
Can you tell me what brand or model of thermostat it is on the wall. Most likely that is at fault, but without model, I can't tell you which wires to disconnect to verify that.
Mar 06, 2010 | Coleman Heating & Cooling
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
My roof top Coleman Mach model 9202-876 only hums when trurned on.
Check to make sure that you are getting power to the fan motor. If you are getting power, then change the Fan Capacitor, if no power then trace the feed back to where the incoming power stops and repair that problem.
Hope this helps,
Jeff
Jul 05, 2009 | Coleman Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
143 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
