Question about Dell Dimension 4400 PC Desktop
How to open the case for a memory upgrade - Dell Dimension 4400 PC Desktop
    President:
  • 2,571 Answers
If you lay the pc down on its side, there are 2 buttons, 1 at each end that you press and then you can lift the lid up.
Here is the link from dell to your model, with pictures showing how you do it http://support.dell.com/support/edocs/systems/dim4400/6J373a00.pdf
Its an acrobat file, so you will need a reader. You can use adobe acrobat reader, i use foxit reader, its smaller and loads quicker. Both are free
Posted on Jul 11, 2010
How to upgrade memory
on the back unscrew the screws there are two places memory could be held take both of one wil be hard drive and other memory
if you have 2 slots put 2x2gbs
if you have 1 slot put 4gb memory in
let me know for further guidance
Mar 30, 2013 | Gateway LT4008u Atom N2600 Netbook
HOW do you open an acer one to access memory slot and hard drive?
Hi James, Here is a step by step video tutorial.
Enjoy your new upgrades.
Oct 22, 2011 | Acer Aspire One D255-2670
Hi. My Dell Inspiron 1525 is not working. The message is try to reseat the memory. What should I do?
If you've added/removed/upgraded the memory recently, the answer would be to open the system up and remove the memory dimms, then pop them back into the original slots they were in. It could be that one of the memory dimms aren't correctly seated in the slot.
If you haven't had the system upgraded recently and you don't want to open the system up the only answer is to take it in to the service center and have the memory dimm/s reseated.
Worst-case scenario is that the memory dimm in question is faulty and needs replacement. This isn't very likely, but definitely possible.
Good luck.
Apr 16, 2011 | Dell Inspiron 1525 Notebook
Purchased two sticks of 1 G memory, want to upgrad...
Assuming you purchased the correct memory and you have two open memory slots it is very easy. Just open the computer case and look on the mother board for memory cards that look like the ones that you purchased. If there are two empty slots you just need to insert the cards into these slots (just ensure that you ground yourself before touching the cards or the mother board by anti-static band or at least touching something metal first).
When you boot up assuming the bios is fairly current should recognize the new memory and you should be good to go.
May 20, 2010 | Computers & Internet
I need to put more memory chips in. where do I do it--the monitor or tower? how do I open the cover?
The memory goes in the tower on the motherboard. Most cases come apart by unscrewing screws on one side of the back. Some have a little lever on the back that, when pushed, releases the side of the case that is opposite the motherboard.
Some cases have a button (large or small) that is recessed into the top and maybe the bottom of the case. When pushed these buttons release the catch inside the case and you can swing it open.
Once open, you will see the memory slots. By pressing the catches on each end of the memory chip, you can release them and lift the chip out. Note the position of the key on the chip socket and the slot in the memory chip when reinstalling memory.
Jan 01, 2010 | Compaq FS7600 17" Flat Glass Monitor
Help to upgrade memory of Dell Dimension 8100
Im sure you mean 1GB of ram.
Upgrading ram is possibly the easiest upgrade to a pc.Firstly shut down the computer and remove the wall plug.
Remove the casing
Make sure you touch something metal away from the case before entering the chassis of the computer... anti static wristbands are good.
As soon as you open the case you will see the dimm slots where the ram goes.
You will find two plastic clips on each ram module, just pull these back to release the ram and insert the new ram.You may need to push firmly down to lock them in.The clips will auto lock.
Just be careful not to push to hard as to damage the mainboard.
Nov 11, 2009 | Dell Computers & Internet
Opening the Dell DHM case?
there is button at the rear top and rear buttom of the machine. press the button and swing open one side of the machine.
to get to the memories, you have to be very careful about the wiring, it is tight and not much space for you work in. do not lay the machine on its side,
May 13, 2009 | Dell Dimension 2400 PC Desktop
Need case removal and upgrade instructions for Compaq 5400US
Use this HP/Compaq link for your case removal & memory upgrade procedure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&dlc=en&cc=us&product=93284&rule=29389&lang=en
Cheers,
gurutim
Mar 19, 2009 | Compaq Computers & Internet
HP Pavilion s3020n memory upgrade
They are usually in a plastic caady which has a latch on it find the latch and release the caddy hope this helps
Dec 14, 2007 | HP Pavilion s3020n (882780985063) PC...
Dell Dimension 4400 PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
