Question about E-Machines eMachines Desktop PC
Ram I have a Emachine pc running Vista with 512 Ram but my computer says i only have 502 ram
    Genius:
  • 1,027 Answers
The other Ram is shared video
Shared video uses ram from your installed ram chips to use for your on board video adapter.
Posted on Apr 19, 2008
  • Mark Williams
    Mark Williams Apr 20, 2008
    IT IS A SHARED MEMORY
    You won't like the resolution if you remove the 8mb buffer in bios set-up, trust me.(it will make your display look like 16color windows 3.1 or worse) You could try it and it will get you back that 8 meg the other is shadow ram, don't mess with that either.
    Your options in advanced video are 8mb and 1mb. My advice, leave it.
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
I have a Packard Bell desk top PC In 2006 I Installed windows vista I noticed I needed a 512 ram as I had 256.I bought a 512 ram I knew were to install It ,I took the 256 ram out and carefully put In...
You put in the wrong type of memory. Put the old 256 back in the computer should power on with no beep code(or all good beep). If this is correct make sure to obtain the same type of memory as the 256. Also both slots must have the same RAM. You cannot have a 128 with a 512. They should both be either 128 or 512.
If you are using Vista you should have a minimum of 1g RAM.
Jun 08, 2011 | Computers & Internet
Slot 1 has 512 MB, slot 2 has 512 MB . Are there more RAM slots or is this Max. capacity
Laptops usually contain two dimm slots. Depending on the operating system whether it's windows xp usually will support 2 1gb ram modules. Vista and windows 7 can usually support 4GB or more ram but more then 3GB is only useful if you are running Visat 64 or Windows 7 64.
Jun 03, 2011 | Computers & Internet
Is it possible to install windows vista in this computer?
No, it needs at least 1GB of RAM and a much better video card.
Jan 16, 2011 | HP Hewlett Packard Compaq D51S Intel...
I have increase the ram from 512 to 2 gb in my emachine desktop, after i restart moniter not getting the video signal. how to fix it?
OK when you increased the ram from 512 to 2G, your hands usually bump the video card and loosen the connection... Crack open your PC again and re seat the video card... This is all pertaining if you have a separate video card in that computer. Just unplug the video card and re snap it in.
Aug 28, 2010 | E-Machines eMachines Desktop PC
No memory
OS Vista minimum want 512 mb ram for run. & yiur only 512 mb ram which is used for your all program. So incres your ram Atleast
1 GB. 2 GB is best.
Jan 30, 2010 | Acer 4220-2346 Notebook
Trying to uprade
upgrade the RAM and find better processing speed of video card and using DDR3 memory
check your motherboard if capable of higher speed RAM..that will help too.
Mar 16, 2009 | E-Machines eMachines Desktop PC
Ram problem
Apr 19, 2008 | E-Machines eMachines Desktop PC
How to upgrade a new compaq presario SR2150NX?
Add more RAM, 512MB ram will slow your computer down because when you run out of ram the computer uses the hard drive as vitrual ram. I have 4GB in my Vista machine and it is faster than XP.
Another suggestion is to turn off the hard drives indexing. Right click on your "C" drive and unhook the "index this drive for faster searching" box.
Jan 05, 2008 | HP Compaq Presario SR2150NX PC Desktop
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
