Question about Acer Computers & Internet
My computer sounds like it will 'blow up' frequently now. It sounds like a fan in my 'tower' is racing then slowing (Acer). Any idea? Thank you so much.
    President:
  • 2,571 Answers
Sounds like your pc is overheating due to dirt, clogged up fans.
I clean mine every couple of months.
Make sure you ground yourself on the case of your pc before you touch anything inside your pc
Open your case and using a small brush clean the fans ( case fans/ graphics cards fans/ CPU fan)
Or you can use an air duster ( a can of compressed air )
I use both, and i use my vaccume cleaner when i use the brush, but dont do this if you are not happy about it.
If you google cleaning my pc there is lots of help
Posted on Jul 11, 2010
Testimonial: "I appreciate the fast response. I will try this and get back to you. Thank you."
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
I've found technical solution on How to Avoid from Overheating
Thanks
Posted on Jun 29, 2011
Makes quick gurr gurr sound in tower. what is happening. computer is slow too
This sounds like a bad fan, could be a case fan, cpu or power supply so need to identify where its coming from by taking the side of the case off.
Mar 22, 2014 | Gateway GT5477E Desktop Computer - 1009589...
Should an ACER 5900 veriton, processor cooling fan, vary in speed ?
Yes all computer fans will vary their speed in order to conserve power. They will speed up when the processor is being used as it generates more heat and needs to be cooled more but if the tower is inactive the fan will slow as it does not need as much cooling.
Aug 29, 2011 | Acer Veriton M265 Minitower Desktop 160GB...
When i turn on my dell dim 8400 the fan races very fast i have to power down and start back up sometimes it takes 2 or three times then starts to work but after awhile it freezes up or if i wiggle the...
Normally, when the fan gets loud and races, it means that the CPU is getting too hot. The normal fault is that the case and ventilation block on the CPU is full of dust.
Disconnect the tower and take it outside or somewhere where a bit of a mess isn't a problem. Open the tower and look inside. Is it full of dust?
Using a dry soft bristle paint brush, CAREFULLY liberate any dust and fluff, if you have a hoover, brush to the hoover to remove dust.
The CPU is under a big metal blob with a fan on the top, Underneath the fan there are a load of ventilation duct in a metal block. See if you can clean them out, compressed air in a can is a good way. In conjunction with the brush.
Check all the vents and fans are clear of dust, including the PSU.
Once done, try it again, does it still race / lockup / close down.
If so, then you may need to renew the heat dispersal grease which is placed between the CPU and the Heat sink (Vented metal block under the fan).
The best place to find how to do that is look on Youtube for CPU changing / fitting / upgrading.
Mar 26, 2011 | Dell Dimension 8400 PC Desktop
My computer tower will not turn on. I tried the steps listed on the HP web site, disconnected the power cord, and all cords connected to tower and held power button for 5 seconds, then plugged power cord...
black screen , totally is here,
one page covers this.
http://pcdied.com/black-screen.html
test one do all Desktop fans run
if not the PSU is bad. 99% we can 1% if PSU is ok.
May 06, 2017 | HP Pavilion a1630n PC Desktop
Fan races slows down races again
the fan is supposed to speed up when the processor gets too hot, then slow down after it has cooled a bit. if it is running more than normal, maybe you should take the cover off the pc and clean the dust out of the cpu heatsink.
Dec 27, 2009 | Gateway (8006549) Heatsink With Fan
Loud racing noise from the tower e 3052
Open up the side of the tower and you will be able to see the fans. You most likely have dust/hair in one of your fans or one of the fans is going bad. You can clean it out with a low pressure air nozzle or dust can.
May 29, 2009 | E-Machines eMachines Desktop PC
Tower making loud fan noises
yes that is because the fan inside of your computer has a bit of dust on it there is not much you can do appart from blowing into the fan then that might help but not much else you can do about that sorry.
please rate my help to you.
thank you.
Apr 21, 2009 | E-Machines W3503 PC Desktop
My tower will not turn on
It sounds as if your power supply is having issues, I would recommend replacing it.  If your good with computers, you can test the power supply: 1. Open the computer tower. 2. Find the main plug which runs from the power supply to the motherboard. 3. There should be 16 wires. 4. Find the green wire, short it to the black wire with a paper clip. 5. If the computer seems to turn on, its your motherboard having issues and you will probably need a new computer.  If it does not turn on, your power supply has failed, and you need to replace it.
I hope this helps!
Apr 03, 2009 | Acer Aspire L100 PC Desktop
When computer is turned on screen stays black and fan races fast
If you put it in another T23, Windows will recognize the hardware change and ask you to re-activate Windows. Microsoft may or may not require you to pay for Windows again.
Mar 16, 2009 | IBM ThinkPad T23 Notebook
Acer 6800
hi first of all check that nothing is touching the blades then spry some oil in the hinge (WD40..) make sure both ways of the fan are open for good air flow if the SUDDEN accelerations annoys you then connect it soo it will run all the time - take the red and black wires to the red and black wires of the 5v hardiscs good luck
Apr 20, 2006 | Acer CASE Mid-Tower ATX P4 350W FAN DUCT...
Computers & Internet Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
