Question about Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special
Installing the blade - Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special
  • 407 Answers
There will be a small lever on the side, up front, where the blade goes. You should be able to lift the handle up and slide the blade into the slot at the head of the saw. Once you lower the lever, it will lock into place. Make sure you also have the right saw blades as some do not fit right. Hope this helps.
Posted on Jul 11, 2010
How to replace blades on a hand held power devil planer (old version)
Try this.
Loosen the fastening bolts Loosen the three bolts that secure the blade.
2. Remove the blade
Now you can use a screwdriver to begin sliding the blade out of its slot. Grab the blade carefully and slide it out the rest of the way.
3. Repeat the process on the reverse side
Now turn the planer's drum around to the other side and repeat the process on the second blade.
4. Install the new blade
Now you can install the new blades. Notice the blades have a notch on them that aligns with the slot on the drum. Align the notch and slide the blade into place.
Loosely tighten the outer two nuts, but don't tighten them completely yet.
5. Align the blade
Make sure the blade is centered so it won't rub against either side of the planer. Once the blade is centered you can fasten the bolts down completely.
6. Repeat the process on the reverse side
Now rotate the drum and install the new blade on the other side.
Jul 22, 2017 | Crafts & Hobbies
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
My poulan pro lawnmower blades are not cutting when running
Are your blades installed up side down?
Is the blade drive belt installed properly or are the blades turning backwards? Is the belt too loose and slipping?
Are the blades dull and need sharpening?.
Oct 04, 2014 | Garden
How to install blades
Almost all scroll saws use a 5 inch blade. You need to take all the tension off your saw before installing the blade. Make sure you are using the right kind of blade. Either it is a pinned blade or non pinned blade. Some saws can use either. Make sure the teeth on the blade is facing down toward your saw table. Clamp the blade into the blade clamps and then add the tension. You should be ready to go now
Jul 12, 2014 | Saws
Need a new blade for blade bracket item #33221 Harbor Breeze 52"
Someone commented "Otherwise the fan blades are on upside down." The blades are reversible, with different finishes on each side, there is no way to install the blades "upside down". Not sure what they were trying to say...
I'm a retired electrical contractor that has installed, quite literally, thousands of fans.
Nov 15, 2012 | Dryers
Blade wont tighten
Here are some directions on installing the blade to ensure the proper procedure has been followed when installing.
  1. Set the blade orbit selector lever to position III.
  2. Fit the supplied screwdriver into the top plunger hole and loosen the internal blade securing screw about 3 to 4 turns counterclockwise.
  3. Insert the blade into blade plunger at a 90° angle to the cutting direction. With a slight upward pressure, turn the blade teeth forward (direction of cut) and guide the back of the blade into the groove in the center of blade roller guide.
  4. Pull gently down on the blade to seat the blade tabs in the plunger.
  5. With the blade in the proper position, securely tighten the blade screw by turning the screwdriver clockwise.
I hope this helps. Please rate on how helpful the answer was. Good Luck and have a great weekend.
Apr 03, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
How to install new blade in Buck bros keyhole saw. It comes with two blades, with the wood blade installed. How do yo remove thw wood blade and install the metal blade?
There is a slot at the back of the blade. Bent the blade out enough to clear the notch in the handle and fold the blade down.
Feb 09, 2010 | Hand Tools
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
Reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Mar 19, 2009 | Garden
Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special Logo
274 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
