Question about Apple iPhone 3G
Battery doesn't keep charge, purchased 5/3/10
Turned off 3G, turned off notifications,turned off location services, anti-lock at 1 minute. Any suggestions?
  • 56 Answers
Try replacing the battery.
Posted on Jul 12, 2010
How can I extend my iphone battery life, any solutions?
>Uninstall the Apps which u do not use regularly, and also try to clear the cache.
>Turning on the screen always can drain the battery.
>If possible try to charge the phone To full(100%) at once instead of charging it always (in bits).
Jan 13, 2016 | Apple iPhone Cell Phones
Tip
Increase iPad, iPhone, iPod battery backup !
  • Minimize use of location services: To disable location services, go to Settings > General > Location Services or use location services only when needed.
  • Turn off push notifications: To disable push notifications, go to Settings > Notifications and set Notifications to Off. Note that this does not prevent new data from being received when the application is opened. Also, the Notifications setting will not be visible if you do not have any applications installed that support push notifications.
  • Fetch new data less frequently: To fetch new data manually, from the Home screen choose Settings > Mail, Contacts, Calendars > Fetch New Data and tap Manually. To increase the fetch interval, go to Settings > Mail, Contacts, Calendars > Fetch New Data and tap Hourly. Note that this is a global setting and applies to all applications that do not support push services.
  • Turn off push mail: Go to Settings > Mail, Contacts, Calendars > Fetch New Data and set Push to Off. Messages sent to your push email accounts will now be received on your phone based on the global Fetch setting rather than as they arrive. If the global Fetch setting is set to Manually, you will not be able to locate your iPhone using the MobileMe Find My iPhone feature.
  • Auto-check fewer email accounts: This can be accomplished by turning off an email account or by deleting it. To turn off an account, go to Settings > Mail, Contacts, Calendars, choose an email account, and set Account to Off. To remove an account, go to Settings > Mail, Contacts, Calendars, choose an email account, and tap Delete Account.
  • Minimize use of third-party applications: Excessive use of applications such as games that prevent the screen from dimming or shutting off or applications that use location services can reduce battery life.
  • Turn off Wi-Fi: Go to Settings > Wi-Fi and set Wi-Fi to Off. Note that if you frequently use your iPhone to browse the web, battery life may be improved by using Wi-Fi instead of cellular data networks.
  • Turn off Bluetooth: Go to Settings > General > Bluetooth and set Bluetooth to Off.
  • Use Airplane Mode in low- or no-coverage areas: Because your iPhone always tries to maintain a connection with the cellular network, it may use more power in low- or no-coverage areas. Turning on Airplane Mode can increase battery life in these situations; however, you will be unable to make or receive calls. To turn on Airplane Mode, go to Settings and set Airplane Mode to On.
  • Adjust brightness: Dimming the screen is another way to extend battery life. Go to Settings > Brightness and drag the slider to the left to lower the default screen brightness. In addition, turning on Auto-Brightness allows the screen to adjust its brightness based on current lighting conditions. Go to Settings > Brightness and set Auto-Brightness to On.
  • Turn off EQ: To turn EQ off, go to Settings > iPod > EQ and tap Off. Note that if you’ve added EQ to songs directly in iTunes, you’ll need to set EQ on iPhone to Flat in order to have the same effect as Off because iPhone keeps your iTunes settings intact. Go to Settings > iPod > EQ and tap Flat.
  • Turn off 3G: To disable 3G, from the Home screen choose Settings > General > Network and set Enable 3G to Off. You will still be able to make and receive calls and access cellular data networks via EDGE or GPRS where available.
  • Avoid Using Winter-board theme
on Apr 04, 2010 | Cell Phones
Tip
Tips and Hints on How to Maximise You iPhone 3GS Battery Life
1. Turn Screen Brightness down to less than a half and turn on Auto Brightness. (Settings - Brightness).
2. Turn off Location Services when you are not using a GPS dependant App. If on a long journey using the iPhone's GPS, only turn the App and the service on every so often. GPS based Apps really eat battery life up!
(Settings - General - Location Services - Off).
3. Turn off Fetch Data. With this feature enabled the iPhone will interrogate the internet or your mail account every so often to fetch data, for example, an e-mail. This drains battery life. (Settings - Mail Contacts - Calendars - Fetch New Data - Push Off).
Or if you really want to keep this feature, just follow the same protocol as above , but instead of switching "Push" off, below that, adjust Fetch Data settings, to fetch on a less regular basis ie Hourly as opposed to every 15 mins.
4. On long journeys when all you need is the iPod functionality, turn Flight Mode on.
(Settings - Airplane Mode Off).
5. Remember to run the battery completely flat every so often. I do it around once a month and then fully charge it again.
6. Turn Bluetooth off.
(Settings - General - Bluetooth Off).
7. For those of us who have an iPhone 3GS or updated software on iPhone, switch on the Battery Percentage for better battery monitoring. (Settings - General - Usage - Battery Percentage On).
8. If you are fairly desperate for battery you can turn off the 3G feature of the iPhone. 3G enables higher browsing speed and better call quality. (Settings - General - Network - Enable 3G Off).
9. Turn Wi-Fi off if not in use. The iPhone will use battery searching constantly for Wi-Fi networks. (Settings - Wi-Fi - Wi-Fi Off).
10. Remember, if you really can't manage with the battery life, you can buy iPhone cases which provide extra battery power.
Good Luck
on Feb 08, 2010 | Apple iPhone Smartphone
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Increase battery life in iPhone4s
turn on auto brightness, reduse sreen brightness,turn off bluetooth when not in use,turn 3g/4g or lte,keep wifi off when not in use ,turn off location services,turn data push off,fetch email less often,turn auto lock to a sooner time ( like 3 minutes or 4),turn off equilizer/EQ)
Feb 24, 2013 | Apple iPhone 4S
How can i push on emails on my 3G iphone/
Getting Started
1 Tap on the Settings app icon on the home page 2. Scroll down and open Mail Contacts Calendars
3 Tap Add Account
4 Select Microsoft Exchange
5 In the Email field, enter your Gmail address Leave the Domain field blank Enter your Google s Username and Password Once done tap Save You might see the Unable to verify certificate error message Select ccept
6 A new Server input field will now appear Enter m.google.com Tap Next to continue
7 Select the Google services that you want to sync. For me, I activated all the available synchronization services. Tap Done google sync enable Your Google sync Push notification services is now set up To activate the push notification you need to turn the Push feature on in the iPhone Settings section.At the Mail Contacts, Calendar section tap Fetch New Data Make sure that the Push is turned to ON Done Few things to note 1 Google sync requires you to be constantly connected to the Web You have to keep your 3G or WIFI connection Always Of for the best result 2 The push notification can be very draining on your battery life If you value your battery life much more than the push technology turn the Push feature OFF for optimal performance Push email support is one of the iPhone 3G s most anticipated features for road warriors but it doesn't work with just any email account Find out how to get hooked up The iPhone 2.0 software available for the iPhone 3G iPhone and iPod touch can t automatically turn any email account into push email It can only instantly send new messages to your phone if your email service supports push email The new iPhone 2.0 software supports push email in conjunction with Microsoft Exchange servers and Apple s Mobile Me service (the replacement for Apple s Mac Apple has labelled Mobile Me Exchange for the rest of us and it can push email to devices running iPhone 2.0 plus keep the device in sync with Microsoft Outlook on a PC or Mail Address Book and i Cal on a Mac he new iPhone s main settings menu now features a new icon Fetch New Data which lets you enable push email You can also schedule the phone to automatically check non-push email services every 15 30 or 60 minutes, or else only manually Which email works with push Push support from other services depends on the provider. The original iPhone supported push email with Yahoo by routing email through i map.apple mail yahoo.com but the service was flaky. This is still the default Yahoo email wizard configuration under iPhone 2.0 but if it refuses to work you can still go into Other and manually set up POP3 Yahoo access Gmail does not support push email only I MAP or POP3 What if I m using G mail or my email from an ISP like iiNet Of course the workaround is to forward your existing email address such as a G mail account, to your Mac account You could even create server side filters on G mail to only forward emails from certain senders to your Mac address to ensure you re not bombarded with push email spam You can also configure Mobile Me to automatically check external POP3 email accounts but this won t get emails from a G mail account to your phone as quickly as it would if your G mail account was automatically forwarding them Push email uses more data The iPhone 2.0 mail client only downloads email headers from I MAP and POP3 servers, in order to save bandwidth When accessing push email services the phone automatically downloads the body of the email and small attachments meaning you need a generous monthly data allowance The iPhone disables its wifi adaptor when sleeping switching over to the mobile data network. This means most of your push email will come down over the mobile data network while the phone is at rest, even when you're within range of a wifi network
Dec 13, 2011 | Apple iPhone 3G
My iphone 3gs won't make phone calls, it keeps saying no service, then searching, then says it has some service but whenever i try to make a call it doesn't go through
It sounds like your phone has been locked,
This download has all the latest updates and all the latest upgrades .
2g, 3g, 3GS, up to 4.2.1
It will unlock iphones that were locked due to an update in itunes.
You will be free to use ANY SIMS card from ANY network.
Keep it on your computer and use it as many times as you want to. (friends & family)
Get FREE Apps, games, customized keyboards, ringtones, themes, toys, utilities, wallpapers, backgrounds, all for FREE !!!
Have your iphone unlocked in minutes not days. (about 5 min.)
It's very easy to use and there is a 30 day 100% money back guarantee !!!
http://tinyurl.com/Debbie38133
Aug 05, 2011 | Apple iPhone 3G
How can I improve my iPhone's battery life?
A recent research conducted on cellphones (smartphones) revealed that most of your battery life is drained by "Internet" and "calls". The more you use your phone for any of these two, the faster your battery drains. Next on the list is "Search for network" which consumes quite a bit of your battery power.
Smaller culprits are WiFi, Bluetooth, Screen brightness, themes, Vibration, etc.
* Reduce screen brightness to minimum
* turn off WiFi/3G/4G when not required (same with Bluetooth)
* if you are out of network area, turn off the mobile network so you cell doesn't keep searching for a network.
* If possible reduce internet usage on your cell phone to improve battery life (ie. if you have a laptop handy, use it!)
* Use a darker wallpaper
* Vibration takes up more battery than ringtones
* use a simple theme
* Dont keep your cell phone charging for long periods (eg. overnight)
* If you plan to buy a new battery, buy a branded authentic one
Hope this helped, thanks for using FixYa!
Apr 11, 2011 | Apple Cell Phones
Quick discharging of the Iphone 3gs battery
perfectly normal. as the iphone is a super-powerful smartphone. also it depends on wich application you are using. 3d games, 3g wireless internet and the PUSH notifications, generally contribute to drain the battery's life. to enlarge you battery's duration i would recommend to disable the push notifications, or at least give them a longer refresh delay. also, it would help if you install a battery monitiring application and lock the phone immediatly after use. the drawback is that you wil hae to manually check you e-mails and other things that depends on the push notifications.
Feb 04, 2010 | Apple iPhone (16 GB) Smartphone
One minutes Battery meter shows full, the next 0% Battery Low
Have you tried powering the phone off and removing the battery? Cleaning the charging contacts on the phone and the charger? Inspect the charging port to make sure there wasn't any damage from the fall. Then restart the device.
Hope that helps.
Apr 22, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Apple iPhone 3G Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
