Question about Toshiba Satellite L305D-S5934 Notebook
When I turn on my laptop the screen stays dark but everything else works got a sloution?
  • 481 Answers
Most probable cause for this is a broken backlight or a bad inverter, both of which are hardware parts that a service person can replace.
Posted on Jul 14, 2010
Why is there no display?
hi
can you plug in another monitor to the video plug on the side of your laptop?
if the monitor works but your laptop screen stays dark your laptop screen needs to be replaced .
If the monitor is also dark then the LCD screen is ok but the inverter needs to be replaced
25717570-m35oz4jvdfvvmght4a51n0jl-5-1.jpg lcd connect to laptop
25717570-m35oz4jvdfvvmght4a51n0jl-5-3.jpginverter
25717570-m35oz4jvdfvvmght4a51n0jl-5-10.jpglcd screen replacement
cheers
May 28, 2015 | Toshiba Computers & Internet
My dell inspiron laptop 1000 screen turns dark every few seconds. if I close the computer half way and open it,it stay bright for a few seconds and turns dark again
This is your back light on your lcd display, To prove that have a flash light handy when it goes dark point the flash light at the screen and you should see the screen and that would mean right there you got a back light going out or the inverter that powers it is going bad. Etherway if this is not your area of work you need to tech it to a computer tech local to have it repaired.
Thanks for being considerate with your ratings and feedback today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 04, 2010 | Dell Inspiron 1525 Notebook
After booting my screen goes dark
Goes dark or just stays dark ? if stays dark then it is the GPU causing problems as it has got too hot at some point, possibly due to lack of ventilation underneath. What sometimes works for me is to turn the machine on and flip it over and rest it on say a tea towel, but have the screen overhang the edge of table so it doesnt damaged it. Then, you need to cover vents and let the machine heat up for say around 10 mins. After this time, turn machine off and back on again, and you will find the screen will come back on. You should then be able to use machine as normal, but keep all vents clear. Some folk might think this is barmy, but trust me it works on most, HP, Compaq, Dells etc.
Apr 07, 2010 | HP Computers & Internet
Dark screen
the problem of the screen is the eider ic , or the capacitor due to overhitting....
Mar 03, 2010 | Samsung T240HD 24 LCD HDTV
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
Dark Screen
Try connecting to an external monitor. If the monitor displays correctly, then the problem is with either the inverter or the screen.
Jan 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Laptop screen.
I think you should bring it to the computer shop. If the spill got inside your laptop, it will be risky to remove the laptop parts and clean it all by yourself.
Nov 20, 2007 | Gateway 450ROG Notebook
Toshiba Satellite L305D-S5934 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
