Question about Leviton 8599 GFCI Receptacle
Screwless GFCI plug plate
How do you install the screwless plate to the receptacle once installed in the wall?
thanks, gale
  • 760 Answers
You first install the adaptor then "snap" the screwless cover to the adaptor. See link to leviton web site: http://www.leviton.com/OA_HTML/ibcGetAttachment.jsp?cItemId=2gfWNEOgKddmIKzlZrTgaw&label=IBE&appName=IBE&minisite=10026
Posted on Jul 11, 2010
Our dishwasher has two grey and one green wire but the instructions say there should be a white, black, and green one. How do we figure out which wire is which?
The green is the earth. If the other two are the same colour, I guess the polarity positive and negative doesn't matter. What does the Bosch installation instructions say?
http://www.doityourself.com/stry/220-wiring-color-code-interpretation
Dishwasher GFCI Requirement ' Electrical Construction ...
ecmweb.com > Forums > Electrical 101 > National Electrical Code (NEC) Mar 4, 2014 - 18 posts - ‎13 authors Sounds like I have to install a GFCI breaker to protect the entire branch ... National Electrical Code (NEC) > Dishwasher GFCI Requirement ...
Dishwasher: Hard Wiring Vs. Plug-In ' Home Guides ' SF Gate
homeguides.sfgate.com > ... > Other Types of Mortgages When you install a pigtail on your dishwasher, you must plug it into a three-prong receptacle. The electrical code does not require the receptacle to be a ground ...
Installing a dishwasher- Does it really need a dedicated ...
forum.mrmoneymustache.com/.../installing-a-dishwasher-does-it-really-n... Mar 12, 2014 - 15 posts - ‎12 authors Installing a dishwasher- Does it really need a dedicated circuit? ... "If your local code requires it on a separate breaker, then put it on a separate ...
electrical - What is code for installing a dishwasher in the ...
diy.stackexchange.com/.../what-is-code-for-installing-a-dishwasher-in-th... Mar 14, 2013 - Current code suggests a dedicated line run to the breaker box for use with the dishwasher. 2008 NEC indicates that the kitchen should have ...
What is the typical dishwasher/disposer electrical connection?
diy.stackexchange.com/.../what-is-the-typical-dishwasher-disposer-electri... Dec 11, 2013 - Checking the wiring for the disposal, might give you some clues as to ... Code that allows Garburators and dishwashers to be cord-and-plug- ...
Dishwasher Connection And Wiring, Oh Boy! - Electrical ...
www.diychatroom.com/.../dishwasher-connection-wiring-oh-boy-10656... Jun 4, 2011 - 15 posts - ‎9 authors Q: should I hard wire the dishwasher or install a receptacle and wire the machine with an appropriate cord and plug? The code says you can do ...
Feb 28, 2016 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Tip
Wiring a GFIC alternative.
When wiring a GFCI (Ground Fault Interrupter Circuit) receptacle you would normally connect the wire coming from the service panel or the hot wire to the LINE connection at the GFCI and then connect the other receptacles you wish to protect to the LOAD side on the GFCI. But let's say you have installed a GFCI in a garage circuit and want to run a wire to the garage door opener from that circuit without the garage door opener receptacle being protected by the GFCI but still want all other receptacles protected. Reason being that the garage door opener will trip the GFCI more often than not. You may also want to have a receptacle for a freezer in the garage. You do not want that freezer protected by the GFCI circuit as it may trip without your knowledge and cause all the food to spoil. Warning: Only install a single plug receptacle for the freezer and not a double plug receptacle. That way only one thing, the freezer, can be plugged into this receptacle as it is not GFCI protected. The way to avoid the breaker tripping is to connect the garage door opener & freezer receptacle to the LINE side of the GFCI. This way it is not protected by the GFCI and there is no danger of that receptacle loosing power due to a tripped breaker on the GFCI. When the GFCI trips power will still be available at any receptacle connected on the line side. On any GFCI you can connect two sets of wires to the LINE side. If you have more than two you will have to connect those together under a wire nut and then use a jumper wire to connect to the LINE on the GFCI. Look at the photo and you will see the 2 sets of holes to connect at the LINE side (Bottom) on the back of the GFCI receptacle. There are also 2 sets of holes to connect on the LOAD side (Upper). Of course you would use a wire nut and jumper to connect all the ground wires.8dd2149.png
on Dec 13, 2009 | Electrical Supplies
It has two grey and one green wire but the instructions tell us black, white, and green
Feb 28, 2016 | Car Audio & Video
Why is the GFCI outlet getting power, but still not working?
GFCI's have 4 terminals. 2 marked Load, 2 marked Line. The black and white wires from the power supply MUST be connected to the LINE terminals. The load terminals is where you connect the outgoing circuit (i.e. plug, light etc). Anything connected to the load terminals will be controlled by the GFCI, so when it trips everything on that circuit will go off until you rest it. The other light/switch cannot be connected to the GFI if you want the switch to control it separately.
Jul 18, 2014 | Leviton R71-N7599-0RI 15 Amp SmartLock Pro...
How do I swap a grounded electrical outlet for an ungrounded outlet in an old house?
While a lot of people have replaced a lot of 2 prong ungrounded outlets with 3 prong outlets, as you probably know, it is an unsafe practice. The National Electric Code (NEC) permitted method is to replace the 2 prong outlet with a 3 prong GFCI outlet such as this:
http://www.homedepot.com/Electrical-Outlets-Plugs-Outlets/h_d1/N-5yc1vZ1xg4Zbp9i/R-202026815/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
For multiple outlets, the usual practice is to install the GFCI outlet at the first outlet in the circuit, then regular 3 prong outlets can be used to replace 2 prong outlets in all the downstream outlet locations as long as the "no equipment ground" stickers that come with the GFCI outlet are used and they are now GFCI protected outlets, per NEC.
Finding the first outlet in the circuit is not always easy. First, determine which outlets are on the circuit, then starting with the outlet closest to the electric panel, disconnect the wires and see if all the other outlets went out. It's kind of trial and error.
Once you have found that first outlet in the circuit, connect the hot wires coming from the electric panel to the LINE terminals of the GFCI and the wires going to the downstream oulets to the LOAD terminals of the GFCI. Full instructions come with the GFCI outlet.
The GFCI receptacles sold today won't work if connected incorrectly, so you will soon know if you did it wrong.
Once the GFCI outlet is installed at the first outlet, all of the downstream 2 prong outlets can be replaced with 3 prong outlets, using the stickers mentioned above to indicate that the outlets are not grounded.
Strange as it sounds, all downstream outlets _must_ be ungrounded when using this method.
Aug 29, 2010 | Hammering
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Doesn't operate when plugged in
The test and reset is a GFCI device. They do go bad sometimes. The solution is to cut that plug end off, and install a regular cord end that is capable of handling the rated amperage of the unit. ( I assume this is 120-volt unit)
You should replace the wall receptacle with a GFCI receptacle where the unit is plugged in to prevent electrocution
May 02, 2009 | Heating & Cooling
Power failure
Code actually calls for the refrigerator to be on a separate circuit for this reason. you may have a refrgerator that may have a higher voltage spike at compressor start up and that is causing the trip. You can try upgrading your GFCI to a 20amp (most are 15amp). Although you may have to replace with a standard outlet if the problem does not subside.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jul 28, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Hobart 20 QT. mixer (HL 200) will not operate on a GFCI receptacle.
you need to replace the gfci,the older gfci's interpret these frequencies as a shock hazard and shut off power to the circuit.you can buy @hobart, part#913053, that should solve the trip problem. dont forget to vote thanks monomoy
Apr 05, 2008 | Food Mixers
Leviton 8599 GFCI Receptacle Logo
211 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Gene Haynes
berniekruege
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
