Question about RCA DIRECTV Satellite Remote Control
My direct tv remote, the white one, won't change channels, etc. I turn the TV on by it;s own remote and all of a sudden last night the remote stopped working.
SOURCE: RCA D771 universal remote won't work on Direct TV receiver
You have to use the aux1 button. Which is says in the instruction manual ! I had to do a code search, but works just fine now.
Posted on Feb 16, 2009
daveknowles
SOURCE: My remote does not work with my bush a632 tv. i
Great Fix... worked fine for me, I thought it was the wireless keyboard and mouse on my PC causing the problem A++++++++++++++++++
Posted on Nov 19, 2011
TVtechmaniac
  • 140 Answers
SOURCE: FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Posted on Sep 13, 2007
quare3
  • 48 Answers
SOURCE: RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Posted on Jan 25, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
Battery leaked in my tv remote....changed batteries, clean debris from inside..it is not pretty clean...now it will not turn tv on or off, but will change channels, volume, etc. I just so happened to have...
Probably not, the PCBoard is possibly damaged are the carbonated buttons.
A replacement remote is fairly cheap as is a one for all with the required functions.
Such a waste I do agree.
Dec 02, 2010 | Sony Bravia Remote Control 148016611
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
shaun
Jun 12, 2017 | Televison & Video
TV won't stay on
You will have to call an Authorized Panasonic Servicer. Any modules bought from them requires an authorization. Since your not a service center, it's going to be almost impossible for you to do anything. Play it safe and have it looked at.
Aug 20, 2009 | Panasonic TH-50PX75U Plasma HDTV
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
May 27, 2017 | RCA TruFlat 27F520T 27" TV
Hello I have a philips universal remote, don't know what model it is I thought all Universal remotes was one Model. Last night I tried using it for my TV to swich from TV to DVD and it just stopped...
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Dec 01, 2008 | Philips Magnavox Learning Universal Remote
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
RCA DIRECTV Satellite Remote Control Logo
1,893 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
