Question about Medical
Shilling AT2 machine. It is printing all 12 leads indivually . We want it to print A standard ekg. How do we reset it ?
  • 157 Answers
SOURCE: Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
Posted on Nov 04, 2008
SOURCE: EKG Machine
3 lead machines are designed to monitor the cardiac rhythm cycle, in 3 of the 12 primary leads. An attempt to use this limited information as a true diagnostic tool would be incomplete and perhaps misleading.
A full 12-lead machine is diagnostic, and looks at the elecrical information from all sides ("walls", ie anterior, septal, inferior, lateral, posterior) of the heart and gives detailed information regarding ischemia and or infarction of the cardiac muscle, electrical conduction system function, electrical axis, chamber enlargement, drug effects, and more.
Hope this helps.
Posted on May 08, 2009
  • 16 Answers
SOURCE: Won't give print out on Automatic but will give on manual
Turn off the machine & then turn on after 10 seconds. than press ALT 1 1 0 STOP in a sequence. That will solve your problem for printing in AUTOMATIC Mode
Posted on Jul 10, 2009
SOURCE: lower half or EKG would not print properly
You should purchase a printer kit. This is a common problem I have encoutntered on this machine and this machine is identical to the Seca CT6I. I have ordered the printer kit from Seca in the UK, the part number is 9740490024 at a cost of £70. It is a straightforward repair.
Posted on Sep 11, 2009
jim4984
  • 797 Answers
SOURCE: Upon pressing the AUTO PRINT the EKG tracing only
Have you contacted Schiller America for support? I contacted them for an operators manual but then saw that you state the manual is too vague. I would suspect that they will be able to pin point the problem and if you mention that the manual is unclear in this area they may update the manual.
Here is the link to their website schiller-america
Good luck, Jim
Posted on Mar 05, 2011
How do you change schiller ekg from 6 lead to 12 lead?
6 lead / 12 lead EKG. It is unlikely that you can do that with your machine. 6 leads are rarely used and would require a totally different internal format. 12 lead Ekg is the standard of care. Chose 12 lead and dont worry about finding a 6 lead. RJ
Sep 26, 2017 | Schiller Medical
ECG MAC 1200 does not print leads III, aVF, V3 and V6, although they are shown on screen
I would reset the machine to factory defaults. Leads to be printed can be manipulated but the factory setting is to print a full 12 lead.
settings-> system setup-> restore defaults-> yes -> hit start until you are back at the main screen and hit print again ( to get a print out)
If it still wont print all 12 leads call us: Discount Cardiology 800-507-8244
Sep 05, 2012 | Ge Medical Systems Ge Marquette Mac 1200...
AT2+ doesn't print
HI,
Its a common problem with Schiller ECG machine. The battery of your ECG machine is faulty. Even if you are using the machine in AC it uses the battery power. The AC power is only used for charging the battery.
When the machine starts to print the battery will drop down and the printing will stop. This is happening with the machine. It will eject the first paper without printing. its normal. Because the machine starts printing on a fresh page only. In your case the machine is ejecting the first paper. When the machine starts its printing in the second page it will draw a large amount of current from the battery for its thermal printing head. If the battery is not proper then it will suddenly drop the printing. The square box you see is not printed by your ECG machine. Its already printed in the paper of Schiller. With this mark the Machine sense the page.
Its a 12 volt 2.3 AH battery. You will not be able to replace the battery from out side any where. For replacing the same you have to open the machine by removing the screws on its bottom. Be care full with the paper tray while removing the top cover. Also do not use any force to open the top cover because there are connections on the top cover.
Here i have added a link to the battery for Schiller AT2 PLUS
Battery
Ajin
Apr 27, 2012 | Schiller Welch Allyn Cardiovit At 2...
I change the paper and now machine runs only in manual mode only. I want to run it in auto mode.
Be certain that you have the correct paper in your unit. THe Schiller AT2 uses a black Que mark on the paper to start the Automatic 12 lead. If the device fails to Que, it will never start an auto run, but manual(rhythm) functions will still remain. The part number paper you should be using is 2157-017A.
Sep 19, 2011 | Schiller Welch Allyn Cardiovit At 2...
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Lower half or EKG would not print properly
Sep 07, 2009 | Schiller Welch Allyn Cardiovit At 2...
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Oct 24, 2008 | Schiller Cardiovit At 2 Light Ecg Machine
Medical Logo
48 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Medical Expert? Answer questions, earn points and help others
