Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Murray push mower 22" Model 223311X8A Briggs & Stratton motor idles slowly, coughs & spits, stops in middle of lawn and won't restart. Had tuned up, then brought back for recheck. Still happening....3 other neighbors having same problem......???
  • Roy Cagle
    Roy Cagle Jul 12, 2010
    Do you think a Briggs excorcism is in order? Maybe clean the brass bolt holding carb bowl on....bad gas too maybe...but the neighbors...maybe they bought the same bad gas??
  • olsen4203 Jul 13, 2010
    Do you know a good exorcist??? It IS weird, they start up and work okay on low, thin grass. As you get into grass that's thicker bladed or a little high they start to sound like they're missing...idling too slow and wanting to stall out. If it IS the gas, is there an additive, maybe dry gas or something we can try without creating further problems? Will try cleaning the bolt in the meantime.
    Thanks for the suggestions and I'll check with the neighbors as to where they purchased their gas.
  • 755 Answers
If your mower sputters when it hits tall grass it might also be a weak coil. Sometimes coils go bad because of poor ventilation due to obstructions in the air path.
Your mower tries to add fuel to compensate for the extra load and the coil cant make a strong enough spark to get across the added resistance the fuel creates. The motor misses and then dies.
The coil looses spark completely and wont restart until the coil cools down. The spark plug ends up covered with fuel too...another thing that wont allow the mower to start!3
You should check for spark the next time the mower quits. If the mower wont throw a spark from the coil lead to the metal fins than you need a new coil. They arent very expensive and you only need to remove the remove the pull starter cover to get to it! Than you can replace the coil following the instructions included with the new part. It's not a bad fix. You might even find a coil on Ebay for less! Bonus!
Posted on Jul 18, 2010
Testimonial: "Thank you so much...that makes a lot of sense since the last time this happened, I took the mower apart, cleaned all parts and put it back together and it worked fine for a few days, now is doingit again. Will try replacing coil. Thanks again! "
    President:
  • Yard Machines Master
  • 1,545 Answers
There are several additives on the market for gasoline, but only a few of them actually help anything. If the additive is relatively cheap to buy, don't expect much results. Gas that hasn't been treated with fuel stabilizer that is a month or more old loses its volatility and can cause issues with engine performance, small and large.
All you guys on the block need to make sure you're using fresh gas, Clean SAE 30 Weight Oil for the Briggs Engines and good clean air filters. Also you can tell when gas is going stale..it starts smelling kind of like turpentine....a smell you'll never forget.
Posted on Jul 13, 2010
How do I refit linkages and springs and in what order on unidentified lawn mower?
Linkage & Spring replacement on a Briggs & Stratton ...
? 7:13
https://www.youtube.com/watch?v=8atnwA4D5lM
Jun 26, 2010 - Uploaded by paisteboy
In this video I replace the two spings at the linkage on the carburetor of my Murray Lawn Mower that has a ...
4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close ...
Nov 24, 2015 | Garden
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
22" Murray Lawn mower cable-PN
murry uses briggs and stratton mowers, you can call them Phone: +1 414 259-5333 in wisconsin, and ask them for the part
Jul 08, 2011 | Kitchen Ranges
Need manual for Murray 20" cut 3.5 hp Classic push
This engine is one of Briggs & Stratton`s basic engines, quite a simple engine, post your problem and i`ll answer,
If you really feel that you need a manual they are available through some outlets, try Wal Mart. or ebay
Jul 03, 2011 | Briggs & Stratton Garden
I have a Scott's riding lawn mower with a Briggs & Stratton 17 hp INTEK OHV model #311-777. I am needing a repair manual for this engine. On starting - engine will turn and stop. Then if you...
These mowers were manufactured by Murray, if you contact the Murray Division of Briggs & Stratton at 800-258-5011 they should be able to assist you further.
Mar 27, 2011 | Briggs & Stratton Garden
Looking for a parts supplier to source Murray push mower 22'' deck
Well I have looked at my suppliers and they are showing it no longer available. So you may have to search around and find an old murray mower that no one is going to fix but has a good deck. good luck.
Sep 29, 2009 | Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Jun 26, 2009 | Garden
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
1,054 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
