Question about HP Deskjet 2330 InkJet Photo Printer
Will not print nor delete printing job - HP Deskjet 2330 InkJet Photo Printer
  • nancie1186 Jul 11, 2010
    So you actually see jobs in the printer? You can try stopping the Print Spool in Admin Tools, then try to delet the old print jobs. Have you rebooted?
  • mtrosalie712 Jul 11, 2010
    I rebooted and that solved the problem. Thank you!
  • 43 Answers
Great to hear!
Posted on Jul 11, 2010
Testimonial: "Solved my problem."
SOURCE: Deleting - Printed
GregoryW's solution worked on a Dell AIO A940, except when I deleted the existing print spool files, the printers disappeared from the Printers and Faxes folder. I had to undelete one of them then the rest of the solution seems to have worked.
Posted on May 25, 2007
jackboy
  • 2985 Answers
SOURCE: Print job stuck and can not be deleted
Have you tried the following?
Start/printers and faxes/ double click on the printer/right click when it opens/select delete  all[or prgressively delete each job on the file.]
Posted on Oct 23, 2007
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
websnail
  • 419 Answers
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
SOURCE: i canceled a print job and it says it is deleting
If you haven't tried restarting your computer, do that first.
If that didn't help try to restart your print spooler.
Click on your start button and then on Run.
Type services.msc and then OK. In the services window find Print Spooler.
Double click it to open, it should say started. Click stop, wait for it to stop, then click start again. This should clear out your job.
Posted on Nov 24, 2009
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Nov 29, 2012 | HP LaserJet 4300 Printer
Print job frozen on Brother MFC-6490CW
Power down your printer to clear the cache and re load from page 3.
Jun 20, 2017 | Brother MFC 6490CW InkJet Printer
Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Mar 25, 2010 | Dell 966 All-In-One InkJet Printer
Lexmark 5600-6600 series delete print job
when you want to delete some print jobs command try to unplug data cable first then cancel print jobs this will sure help your query
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 25, 2010 | Lexmark X5150 All-In-One InkJet Printer
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
Deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Jul 01, 2009 | Dell Inkjet 720 Printer
My last print job gets stuck deleting in the queue!
Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Feb 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
I click print and nothing happens.
go into your print que and see if there is a job prior to current print job that did not print... highlight the prior job and right click, scroll to delete and after you delete prior print job, job and printer should start up
Jun 05, 2008 | Office Equipment & Supplies
HP Deskjet 2330 InkJet Photo Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
