Question about Samsung PN50A450 50 in. Plasma HDTV
I have a samsung plasma tv model PN50A550SIF, problem is no sound or picture just clicks
electrotech1
  • 1126 Answers
SOURCE: Samsung model HP-T5054 Plasma TV
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Posted on Oct 16, 2010
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
techbuster
  • 5081 Answers
SOURCE: SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Posted on Jul 04, 2009
stonephoenix
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
  • 6 Answers
SOURCE: Have sound but no picture on Samsung plasma
It's a pretty common problem. The no picture but sound problem is usually the y sustain board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
How to fix my samsung plasma tv
Check error code (5 blinks) in TV's operator manual.
Or visit Samsung's website with model and error code.
Oct 05, 2017 | Samsung Televison & Video
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
How to fix a 58 in plasma tv that makes a clicking noise ; no picture
SOUNDS LIKE A FAULTY RELAY HAD THIS FAULT PREVIOUSLY ON SAMSUNG -SONY-TOSHIBA
Jul 25, 2015 | Samsung PN58B560 58 in. HDTV Plasma TV
Samsung tv sound but no picture
Based on the class action suit against Samsung, it's likely the capacitors buldging. My TV purchased in late 2007 was a "victim" and the tv did the turn on/off with no pic or sound. There is a limited number of tv models and now a March 2013 time limit. To see if your TV is one that qualifies for a free inhome replacement, look at these links:
www.samsung.com/capacitorsettlement/
http://arstechnica.com/gadgets/2012/10/how-samsung-spent-300-fixing-my-out-of-warranty-tvs-click-of-death/ (shows pictures, model numbers, etc.)
The Samsung repair was quick, but I had to get the TV off the wall mount and ready for the repair. They don't take it down or do any of the cable/line connections. If you are unsure if your model is one that qualifies, call the special 800 number given in the class action ruling.
Mar 02, 2013 | Samsung PS50Q97HDX 50 in. Plasma TV
Samsung ps42b430 clicking sound
recheck first the wiring, if ok check bad component parts at the buffer board.
Oct 10, 2012 | Samsung PS42B430 42 in. Plasma TV
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Samsung PN50A450 50 in. Plasma HDTV Logo
172 people viewed this question
Jerry Greenberg
Jerry Greenberg
