Question about Sony Walkman NWZ-S616F MP3 Player
Charging Up The Battery
I have a Sony Walkman the model number is NWZS616F and I need to know how to charge up the battery?Thank you,Fran Rolon
  • 5 Answers
SOURCE: Sony Nwa3000 appears dead??
First things first-have you pressed the reset button on the bottom of the unit? Secondly- try updating the firmware on your unit the manual way - Go to this link. http://www.sony.co.uk/view/ShowArticle.action?section=en_GB_Products&articlesection=1&article=1154694485490&productcategory=%2FAudio%2FNetwork+Walkman&productmodel=%2FAudio%2FNetwork+Walkman%2FNW-A3000&productsku=NWA3000B.CEK&site=odw_en_GB Go to download the latest version of Sonicstage but dont actually do it. At some point there is a link to update your firmware to version 3.0. Try doing this again, going through the update procedure it suggests, even if you already have 3.0 installed. This might work. Worth a try at least!
Posted on Jan 05, 2007
SOURCE: MP3 Sony Walkmna not charging- Got cut off before problem was solved
escuse me i did ecxactly that and my walkman is almost out of charge ans till not charging i press the reset buttons god knows how many times and i checked the wire in so many different plugs of the computer it doesnt work plz plz some one help me i need desperate help
thankyou do you know great it would be if some one told me how to fix the problemo
Posted on Aug 25, 2008
  • 76 Answers
SOURCE: sony walkman 4GB NO RESPOND/FROZE with screen saying"WALKMAN"
there is a reset button hold it down for 10-30 seconds....prolly what you are doing is not allowing the comp to disconnect thru icon 1st before you dissconnect the mp3 player.....btw if you do this to often the computer can start acting up
Posted on Dec 02, 2008
Press the reset button and plug it into the charger afterward. The music won't be lost trust me. It just resets the time settings, as well as the music equalizer.
Posted on Jan 10, 2009
SOURCE: Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
Posted on Sep 14, 2009
I HAVE SONY WALKMAN NWD-B103F- BATTERY DOES NOT LAST FOR 10 MINUTES-AFTER CHARGING ON COMPUTER
The battery does not hold charge. It is weak. Replace it with same type number. Brand name of the battery isn't a matter, check its type number printed on it.
Jul 09, 2016 | Sony Walkman Audio Players & Recorders
Is it possible to replace the battery in my Sony MP3 Walkman model NWZ-E464
From the user guide:
  • When usable battery life becomes half the usual time, even after charging the battery fully, the battery should be replaced.
  • Consult your nearest Sony dealer.
This would lead me to believe the battery is replaceable.
Jan 08, 2015 | Sony Audio Players & Recorders
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
Battery is not charging but its as if it is on the front face display
How do you know the battery is not charging? I'm assuming you mean it charges according to the display, but when you disconnect the battery life is very brief. This would be indicative either of a defective battery or power supply.
Try changing the battery, this may rectify.
I hope this helps.
Mar 18, 2011 | Sony Ericsson Walkman W595 Cell Phone
My Sony Walkman MP3 player will not power on. I thought that it was because the charger was broken, so I bought a new one. To my surprise, it was not the charger.
If the battery was completely dead you may need to leave it plugged in for a few minutes for the battery to be charged enough to turn the unit on. Also sometimes the battery can be so bad that it will no longer take a charge. The charging mechanism inside your GPS may not be charging the battery properly either.
Mar 08, 2011 | Sony Network Walkman NWZ-S545 Digital...
Dear Sir, i have 435f if on the player its come walkman symbol and suddenly offff,,,,,,,,,,,
Try charging the battery. To do this, connect one end of the USB cable to the walkman (make sure the w. symbol is facing up), and the other end to your PC. To get a full charge, it will take approximately 4 hours and when it's done, you will see a battery indicator displaying "Full" on the battery. It maybe also that your battery life is used up. You get a certain number of charges (500)before your battery is used up. If that's the problem, you will have to get a new battery. Reply to this solution if this doesn't help.
Nov 27, 2010 | Sony Walkman NWZ-E435F Digital Media...
Sony erricson w705, wont charge the battery, it comes up with a message saying it cant charge the battery please put a sony erricson battery in, but it is a sony erricson battery and when the battery was...
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
Oct 08, 2009 | Sony Ericsson Walkman W705 Cell Phone
Sony NWZS616F 4GB red Walkman MP3 player with
you have to go on youtube, type in "how to put a video on the nwzs615f" even though it is a different model, it should still work! Also, i would recommend going to download.com and getting xilisoft video converter ultimate. this way you can convert the whole video! good luck! please rate this answer please
Jul 03, 2009 | Sony Walkman Video NWZA818 MP3 Player
Sony walkman 4GB NO RESPOND/FROZE with screen saying"WALKMAN"
Get a pin and push the reset button located at the bottom of the unit. Hope this will help.
Dec 02, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
