Question about Whirlpool GGQ8831L Gas Dryer
No glow plug glow, hooked up a pigtail, it works fine, also no primary gas valve humm, hooked up a pigtail, it works fine. I suspect no feed from the timer to start the glow plug.Do you agree? I need a schematic. Thankyou Whirlpool 110 72622100 ser.1802498
  • 259 Answers
Your service manual, or wiring diagram for this machine should be located in the control panel housing.
Most likely you have a blown thermal fuse. This part is located on your blower housing right behind the lint screen duct. The power for your gas valve/burner assembly is routed through this part and will be cut off should the drum temperature get too high during operation. The part is a skinny white colored item with a black strip down the center, a quick check would be to see if it has continuity, or simply bypass it briefly to check it. DO NOT leave the part bypassed.
To access the part remove your lower front access panel, remove the lint screen for m the dryer and then remove the two quarter inch screws on either side of the lint filter housing to remove the housing.
The part number is a 3392519 thermal fuse.
Good luck to you on this.
Posted on Jul 11, 2010
  • Robert DeStevens
    Robert DeStevens Jul 11, 2010
    Mike, I apologize, just realized you gave a kenmore model number on this unit, but it got listed as a whirlpool gold. The thermal fuse part number is the same, but the location is entirely different on the kenmore number you posted. The thermal fuse on this is located at the rear of the dryer on the blower duct to the left of where your vent connects. You will need to remove the rear cover from the dryer to get at it. Also your wiring diagram should still be located inside the console either in a packet or glued to the inside of the rear console cover.
    Again, Good Luck on this!!
One side glows like a champ. The other side, dedicated for High setting, pooffs when I turn it to high, then kind of fickers and barely glows. I have a fuel filter and a six foot hose off of a 20#...
dirt , foriegn material,spider web in gas feed line to the right side ceramic element of mr heater big buddy. take plastic back of heater
off, many #1 philips or smaller screws. find large air induction holes
in gas feed line to right side ceramic element and blow out with compressed air and fine tiped /straw tipped air blow gun.
straw tipped air blow gun is a better tool for this.
reassemble & try lit mr heater again.
If it dont work after air blow gun the gas feed tube, you didnt get the gas feed tube cleaned out ,***** & span (something still in there ) and will need to disassemble the gas feed tube and inspect for foreign material blocking the gas flow.
If this dont work,need to take the gas feed line off the gas valve attached to Mr. heater red knob. red knob just pulls straight out, might need pliers to grab red knob.
check gas valve output for dirt etc that stop gas from getting through. check inside the gas line to the ceramic burner for dirt,
foriegn material- that stop gas from flowing through strong.
any stopage of gas flow , even a slight stopage or dirverting of the gas flow, spider web is common, will stop ceramic element from burning properly.
needs to be clean ,like a carburator.
Dec 27, 2010 | Mr. Heater Big Buddy Heater
How do u replace heating element
there is no electric heating element in a gas dryer,either the ignitor bar/glow plug is defective or the flame sensor is bad or the coils on the gas valve primary and secondary are weak and wont hold gas valve open
Jan 30, 2010 | Amana ALG331RAW Gas Dryer
Glow plug lights but flame wont always light
If the glow plug is working, but the dryer won't light, then it is most likely caused by the gas valve coils. These electrical coils are located right above the gas valves. When these solenoids are energized, they open the gas valves and permit the burner to light. If faulty, they don't open the valves to permit gas flow. Due to the difficulty in testing these solenoids, if any are suspected of being faulty it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Aug 23, 2009 | Dryers
Electric ignition element heats, but gas does not come out/ignite. The broiler on top side works fine.
even though the ignitor is coming on it is probably too weak to open the gas valve. with an amp probe you should read 3 amps and above. anything under 3 amps you should replace the ignitor. hope this helps
Aug 21, 2009 | Ovens
Tumbling fine no hot air. is a gas dryer
First, check that the ignitor is working properly. It should glow visibly if it is working. If the ignitor seems to be functioning properly, then I would suspect the gas valve coils. These electrical coils are right above the gas valves and when these solenoids are energized they open the gas valves and permit the burner to light. If they are faulty, the gas valves don't open so no gas gets to the burner. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at the same time if any are suspected of being faulty. Hope this helps and best wishes.
Aug 11, 2009 | Dryers
Glow plug lights but does not fire gas everything
This is most likely faulty gas valve coils. These electrical coils are located just above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If faulty, the gas valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Jul 23, 2009 | Kitchen Ranges
Oven burner does not lite.
valve gets stuck perhaps but the fact that the ignitor even glows tells me there power running through the valve, no glow= bad valve. Id have to say sounds as if you have a bad ignitor, yo can try "tapping" on the valve as teh ignitor is glowing, perhaps this will free it up( doubt it). the valve is the little box the ignitor wires goes back to,and gas feeds into as well
Nov 26, 2008 | Kitchen Ranges
Dryer turns but no heat
In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. If 3-5 yrs old, the igniter has probably gone bad. ($50.00 to $90.00 for igniter). The coils also have an occasion to go bad, albeit rarely.
May 11, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Tappan - Model 36-3052-23
I suspect you may have a bad igniter. They will still glow nice and hot, but if they are weak the gas valve will not open. This is actually a safety feature. Depending on which type you have, the glow bar igniter is supposed to draw a certain current potential before the gas valve will open. Here's the current readings for both types: Round Glow Bar: 2.7 to 3.2 amps Square Glow Bar: 3.2 to 3.7 amps I would try to to determine if the igniter is good or bad before proceeding with a gas valve replacement. Generally, the igniter is a common fail item. Let me know if this helps.
Sep 06, 2007 | Tappan MGF500PBW Gas Kitchen Range
Whirlpool GGQ8831L Gas Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
