Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Lamp i received the lamp without directions. are they posted anywhere?
Http://esupport.sony.com/US/perl/model-documents.pl?mdl=KF50WE610&LOC=3#
click on the operating instructions link as this is a PDF version of the manual that came with the television. look at pages 13 - 16. this will help you replace the lamp. as a side note, yes you do have to pull on the front cover. don't be intimidated as it will come off with a little applied pressure.
Posted on Apr 26, 2008
I have a 2004 Silverado and when I open the passage door none of the inside lights come on but the drivers side does please help
The left and right front door courtesy lamps are controlled, and receive voltage and ground from the drivers door module (DDM) and the passenger door module (PDM) respectively. The body control module (BCM), DDM, and the PDM communicate through class II serial data for the lamp illumination commands and the door ajar switches.
The remaining courtesy lamps are controlled and receive voltage from the BCM. Voltage for the courtesy lamp supply voltage circuit and the backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. Ground is provided to the footwell lamps and all courtesy/reading lamps at G203. Ground is provided to the right middle and right rear door at G306. Ground is provided to the left middle and left rear door at G302.
There could be a DTC - diagnostic trouble code stored in the BCM
DTC B2615
The body control module (BCM) receives a ground signal from the door jamb, liftglass/liftgate if equipped, or courtesy lamp switches requesting courtesy/dome lamp illumination. When this occurs, the BCM directly sends a voltage through the courtesy lamp supply voltage circuit illuminating the courtesy/dome lamps.
Voltage for the courtesy lamp supply voltage circuit as well as the backup lamp supply voltage circuit is from the left instrument panel fuse block TBC 2B 15-amp fuse directly through the BCM to these circuits
DTC B3801
The body control module (BCM) monitors the courtesy lamp switch signal circuit in order to determine when the courtesy/dome lamps should be illuminated. When the BCM senses that the courtesy lamp switch signal circuit is grounded when the switch is activated, the BCM will illuminate the courtesy/dome lamps.
Inspect the following related body control module (BCM), driver door module (DDM), and passenger door module (PDM) data parameters. Refer to Scan Tool Data List or Scan Tool Data Definitions for typical values and definitions:
The courtesy lamp switch
The interior lamp defeat switch
The door ajar switches
Was a problem found?
Go to Step 7
Go to Step 10
Oct 20, 2015 | Cars & Trucks
How to reset SVP TCP-1020 tablet
In most cases, the battery comes loose from the main connection. Those tablets do come apart, the back just presses on.
Jul 30, 2014 | SVP 10-inch Tablet
I have an EP2500, which burns speakers. I connect with a lamp in series, and when it receives high frequency signals, lights the lamp, the output looks correct, but consumption is increasing dangerously....
There was an suggested solution here for your problem.
There are electronic components which seems to be undiscoverable
for a moment.
• The fault could be anywhere from the differential input stage
to the VAS circuits.
• One has to check thoroughly components , and proceed
troubleshooting without the power transistors connected.
• Check for offset voltage on each of the main amp output.
• Check for idling current
A good amp never produce an over of 0.7V on its output.
Jul 30, 2012 | Behringer EUROPOWER EP2500 Amplifier
I want to find out the life expectancy of the bulb (lamp) that comes with the Optoma projector model VDDVGG
We tracked it when we first bought ours. The lamps go anywhere from 800 to 1200 hours. First, I don't think the manufacturing process is very consistent so they very a lot. Also, it seems the more you turn them on/off the shorter the life. If you use for longer periods, then they last more hours.
You might be able to get 2000 hours out of one if you just leave it on without turning it off but that is a waste too.
-Mark
May 18, 2011 | Audio Players & Recorders
I have a ceiling light that does not have a switch anywhere. Can a hunter 27185 remote control be used to control the ceiling light fixture only. There is no fan in this scenario. How should it be wired?...
Connect the lamp output wire of the receiver to the hot wire of the fixture, and the incoming hot wire to the hot input of the receiver. Be sure to insulate the fan output wire(s) so nothing nasty happens if someone presses the fan on button.
Check the remote control manual to see if you can use compact fluorescent bulbs. You probably cannot if this is a dimming lamp control; most CF bulbs flicker wildly if used with dimmers, and will not last long.
You can also buy remote lamp-only switches.
Sep 22, 2010 | Hunter 27185 Remote Control
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
Need a part cannot find anywhere goes behind the lamp on the chassis to direct heat out of set
Try Samsung parts info at 800-634-8276 or 1-800-SAMSUNG cust service. This kind of part is not normally stocked anywhere else.
Apr 14, 2010 | Samsung HL-S5086W 50" HDTV
How to replace a fog lamp with replacement bulb only on 2002 toyota 4runner sport edition???? the three screws on the bottom?
Well, these are the steps and I will post the pic here in a second...looks like 2 screws...but like I said, you can see the picture for direction on this.
Remove or disconnect the following:
Front turn signal lamp
  • Connector
  • 2 screws
  • 2 claw fittings
  • Fog lamp assembly
  • Fog lamp bulb as shown
  • Fog light unit
  • To Install
    1. Install or connect the following:
      • Fog light unit
      • Fog lamp assembly latch the 2 claw fittings and 2 screws
      • Connector
      • Front turn signal lamp
    Trying to post the pics now....
    May 14, 2009 | 2002 Toyota 4Runner
    Synchronisation problems
    try to change the sound setting of your reciever.. try all options of sound setting..
    Dec 27, 2007 | Onkyo TX-DS777
    Direct source
    I downloaded the manual from some site 5 min. after I posted and it was simple. Turn the reciever off, then press and hold the enter button while you turn it back on. It worked, no problem...
    Dec 03, 2007 | Aiwa AV-D58 Receiver
    Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
    19 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
