Question about Optoma EP7155 Projector
My Optoma EP7155 DLP projection turns magenta
My Optoma EP 7155 DLP video projector works great for awhile, then suddenly the images or video turn shades of magenta. The image on my computer is normal-colored. The projector has not been changed from default color settings - at mid-range. When I use it the next day, it's fine. Any ideas?
  • Daniel
    Daniel Oct 10, 2018
    Hi!
    Hope it's not too late and you didn't throw out your projector :)
    If using the HDMI-to-VGA adapter, verify the HDMI connector is securely connected to ScreenBeam receiver and VGA cable is connected to the VGA adapter.
    The projector is set for the wrong type of incoming signal. The purple hue seen is caused by viewing an analog RGB signal in the YPbPr or component video mode.
    Change the Projector's Signal Input to either "Auto" or "Analog RGB".
    Enable the VGA Compatibility mode in ScreenBeam receiver’s setting.
    It worked with my Optoma, first herehttps://wisepick.org/best-short-throw-pr...
  • 3 Answers
SOURCE: OPTOMA EP716
ALSO CHECK YOUR FAN. IF THE FAN OR A HEAT SINK IS NOT WORKING PROPERLY (I.E. THE FAN MAY JUST NEED TO BE CLEANED OR REPLACED, THERE SHOULD BE A SMALL HEAT SINK. IF CLOUDED W/DUST, IT WILL KEEP THE OPERATION SHORT). ALSO CHECK IF YOU HAVE SET ANY TEMPERATURE SHUTDOWN PARAMETERS. IF YOUR LAMP HEATS UP FOR SO LONG AND REACHES A TEMPERATURE THAT WILL AFFECT THE CIRCUITS, THIS OF COURSE WILL SHUT DOWN YOUR UNIT UNEXPECTEDLY. HOPE THIS HELPS...JGUAM
Posted on Apr 05, 2008
Marrie
  • 563 Answers
SOURCE: Optoma EP 732H Blue/purple tinge
Hi jmm521
Try using a different VGA cable as connection - WILL solve your problem !
Thanks for using Fixya !
Posted on Apr 30, 2008
SOURCE: Help needed for Optoma EP 719 DLP PROJECTOR
picture upside down
Posted on Jul 28, 2008
dgostl
  • 5 Answers
SOURCE: optoma EP 738
Also make sure the bulb replacement cover is on, cause there is a little switch that cuts power if the cover is off.
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: color problems
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Posted on Dec 22, 2008
I have an Optoma HD 8000 projector and while watching TV the lamp will turn off what can I do to repair the issue
if the lamp, lamp driver,power supply,Scaler Board and Formatter Board were good.
perhaps it is over temperature protection.
whether you checked with the air filter( dust filter) is clean or dirty?
Jul 02, 2014 | Optoma EP7155 DLP Projector
Hi, I have a projector Optoma EP7155 and it appear white and black spot like dead pixel, I would like to know where I can buy a DMD chip with the CCD and how much it will cost. Thank you
global projectors is one source. You need to find out from Optoma the chip you need or take apart the machine and look at it. From China they run about 200 bucks. I've only done Mitsubishi so far.
Dec 16, 2012 | Optoma EP7155 DLP Projector
The projector is showing the image upside down and back to front. How do I remedy?
Hello
Check the Projection Setting on the Setup Menu of the OSD.
The projector has an OSD that lets you make image adjustments and change settings.
On the setup menu, select "Projecion"
Use " > " or " < " key to select from four projection positions.
For more details, go to page number [33] of its user manual. If you haven't the user manual with you now, send your email address to me by FixYa comment box. I've the downlaoded user manual to your projector. I can't send it to you by this window as this window does not allow me to upload PDF files by it. If you send your Emai ID, I'll send a copy of the user manual to you by return mail. OK.
Nov 28, 2011 | Optoma EP7155 DLP Projector
Optoma security code reset
Hello
What is the model number of your Optoma Projector?
Nov 10, 2011 | Office Equipment & Supplies
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
Optoma EP7155 gets very hot and shuts down.
Hi
Possible filter problem since its overheating. clean up filters and make sure that you use projector in an open area so air can cool it off while running.
Hope this helps
Mar 26, 2010 | Optoma EP7155 Projector
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP7155 Projector Logo
105 people viewed this question
Top Optoma Office Equipment & Supplies Experts
Computer Links
neOen
Level 1 Expert
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
