Question about Canon EOS 400D / Rebel XTi Digital Camera
Screen resolution not sufficient to install ver.30.0 software.
  • cyhollidaywi Oct 20, 2008
    error message......
    insufficient screen resolution
  • Anonymous Feb 10, 2009
    same exact problem
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Posted on Jun 08, 2009
I have digital camera of canon 'powershot a470'
But at the time of installation of cd following message is showing.
"The screen resolution to execute digital camera solution disk is not sufficient"
what is the solution for this?
Thanks
Amol
Posted on Oct 09, 2008
While trying to install Canon Camera software, I'm getting a message that says ''screen resolution to execute digital camera solution disk is not sufficient.
Select the "Start" menu in the lower left corner of your computer monitor screen. Select "Control Panel", then double-click on "Display".
Click on the upper "Settings" tab, then move the slider bar to the right, to at least 1024 x 768 pixel. Then hit Apply or OK. This will increase the screen resolution of your computer monitor so that it will be compatible with the Canon software.
Oct 15, 2009 | Canon Cameras
I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Dec 30, 2008 | Canon Cameras
Intalling camera software.
Greetings Shayy,
Generally screen resolution refers to your computers resolution which is controlled via the control panel of your computer. I would try fiddling with other screen resolutions to see if this helps. This will cause items on your computer to either be larger or smaller than you are used to, but you might find you like it better.
You would go to control panel>display>settings, to adjust this.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Can't install the solution disk
Click on "Start" lower left corner of your screen, and select "Control Panel". Then double click the "Display" icon. Then click on the "Settings" tab.
Slide the screen resolution slider bar 1 click to the right to select 1024 x 768 resolution. Then click OK. You should be able to install it now.
Apr 12, 2008 | Canon PowerShot A450 Digital Camera
Unable to install the canon Software
Under your control panel in "Display" go to the settings tab and slide the resolution bar to:
Screen resolution: 1024 x 768 pixels or more,
Color quality: Medium (16 bit) or more
That should do it.
Dec 06, 2007 | Canon PowerShot S5 IS Digital Camera
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon EOS 400D / Rebel XTi Digital Camera Logo
840 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
