Question about Hotpoint HSS25GDMWW Side by Side Refrigerator
Water is not comming out of drink dispenser.
Stopped about two week ago and started working again. Now it stopped working again
  • Hotpoint Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerwater is not comming out of drink dispenser. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
  • auto god Jan 30, 2011
    I had same prob first idisconnect coupler at bottom of door close door than select water
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a refrigerator model #GD5PHAXMS10 icemaker that stopped working about two and a half weeks ago. At that time the water the water works dispenser worked like normal. Today the water dispenser...
The first thing to do if you already haven't is replace the filter,it's in the grill/kickplate below the freezer door. If you have relpaced filter,need to pull refrig from wall and check that their is good water pressure from house plumbing,if it is good the water valve the sends water to icemaker&door dispenser when water is called for is going to be the problem.The part # for that valve is 4389177 it could be purchased at your local appliance parts store on oline at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
The filter BUT NOT the water valve could be purchased locally at Sears,Lowe's or Home Depot
I hope this helps you to diagnose your icemaker/dispenser
Gene
Aug 07, 2011 | Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water dispenser not working no water. ice stopped working a few weeks ago. fridge and freezer work fine otherwise.
If both stopped at the same time. Check the water control valve in the back of the refrigerator. Make sure the wires are connected and have not become loosen.
Jan 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Drinks depencer not working
check the dispenser lever switch
May 02, 2009 | Refrigerators
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
The water dispenser has stopped working!!!
could be a water solenoid problem (at the back portion where water from the sink enters ), or a micro switch in the dispenser area problem.
also, check if u have a water filter. could be clogged already.
tnx 4 using fixya,
drcool
Oct 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GDMWW Side by Side Refrigerator Logo
65 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
