Question about Haier HRT02WNCBB (17 cu ft) Compact Refrigerator
No power at all. i plug it in and nothing happens. outlet is good. almost new fridge..
  • 10,515 Answers
No power at all - I am buying the information that the plug socket is fine and the refrigerator is ' dead ' i.e no lights and no fans. ( Silent as it was never plugged ).
This indicated Faulty motherboard ( 90% ).As it was almost new, i would not recommend you to open and inspect the board as it would void the warranty,if any. Moreover, it could be dangerous if you have no appliance / electronics repair experience.
If the fridge is out of warranty and wanted to repair this, kindly revert and i would be glad to tell you few pointers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 11, 2010
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Relocate to new home, plugged in printer and turn on switch- nothing happens. Is there a fuse I can check?
First thing I would Check is that the outlet you have plugged it into has power just to humor me plug a known working device into the same outlet to see that the outlet has power if it does then check that the power cord to printer is plugged into the socket and back of printer tightly also some power cords for printers seperate in the middle near the power converter be sure that is plugged in snuggly, If that all checks out Check inside the printer for damage which may have happened during the move, open all printer access doors and visually inspect all areas inside printer for signs of damage. If that all Looks Good Go Here to get support on this subject.
Thumbs Up if Helpful and Feedback is Appreciated!!!
Jun 19, 2011 | HP LaserJet 3050 All-In-One Printer
My lg refrigerator just gave out. Its plugged in but its not working. I have checked the circuit brakers and everything is fine. Is this fixable or do i need a new fridge? I have owned this one 2 years
I had this problem a while ago. It may not be the circuit breakers but the outlet where fridge is plugged may have gone bad. Plug fridge into another outlet and see what happens. A 2-year old fridge is almost brand new.
Jan 23, 2011 | LG LSC27910 (265 cu ft) Side by Side...
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No power to refrigator check plq and it is hot Light in sisde dont even work
It could be a loose connection where the power cord is connected to the refrigerator inside or a bad power cord. If that doesn't solve the problem you may consider calling a repair person.
Good Luck,
GilShultz
Mar 01, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator no power
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Feb 21, 2009 | GE PSS26SHRSS Side by Side Refrigerator
Fridge has been working great then this morning no power.
try plugging your refrig into a different outlet, or plug something else into the outlet the refrig is plugged into to verify power to the outlet.
Jan 30, 2009 | Samsung RS2630SH Side by Side Refrigerator
Haier HRT02WNCBB (17 cu ft) Compact Refrigerator Logo
60 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
