Question about General Electric GSS22JET Side by Side Refrigerator
Water flow to ice maker has been reduced to
Water flow from ice maker has been reduced to practically a trickle. The water line is not plugged. The ice maker has worked fine for 4 months but suddenly shows the symptoms I describe.
  • GE Master
  • 43,501 Answers
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshootingwater flow to ice maker has been reduced to - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
Water flow tube on ice maker leaking by causing ice blockage
When the ice maker calls for water, the valve sends water to the ice maker in the appropriate amount and then shuts off, sending no more water until the ice maker calls for it again. If the water fill line is freezing up, this will cause a leak the next time the ice maker calls for water. The water has to go somewhere. The problem is more than likely the the water valve. It is not shutting off completely and it is allowing a small trickle of water to be constantly sent to the ice maker. This causes the fill line to freeze up and clog. Replace the water valve and defrost the water fill line and solve the problem.
Apr 06, 2014 | GE Refrigerators
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
Water supply to the ice maker is freezing up,how can it be fixed?
Hi
Over time the inlet valve becomes partially plugged, reducing the outlet pressure and reducing the water flow rate into the icemaker. If the flow rate is too low then the water will gradually freeze in the tube until it becomes blocked entirely. Many times low water pressure will cause this. You can perform a taste. Get a piece of tubing and attach it to the inlet valve. Run this piece to a container and see if you get any water while the power is off to the valve. You might have a valve that is not shutting completely off. Hard water might cause this. Killing the power to the valve will make the valve inoperable. Actually the purpose of killing the power is to see if the valve is allowing water to bypass even when there is no signal from the switch to do so.Bad inlet valve could be the possibility. So it needs to be ordered and replaced because the valve isn't sealing off properly and it's causing the water to trickle through or drip through the fill tube sometimes, then it freezes before it reaches the icemaker and over time it will clog up the fill tube completely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 04, 2011 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker not making ice water dispenser works well
There are 2 solenoids, one controls the water dispenser the other controls the ice maker water supply. Follow the tubing down the back of the refrigerator to find the ice maker solenoid. If the line is frozen between the back of the refrigerator and the ice maker it won't make ice either. If the line is frozen you need to check to see if the solenoid is leaking, this allows a trickle of water to continously flow through the lina and freeze.
Jan 08, 2011 | Refrigerators
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
Water on the ice maker doesn't shut off - drips into the ice pan
Most models of Ice makers have an automatic timer for the amount of water that is allowed to enter the Ice Maker tray. If your timer valve is going bad you need to replace it. First I would reduce the amount of water coming from its source. There should be a tapped valve under your sink, connected to your water line. You have to turn the top of the valve clock wise to reduce the amount of water the is going to the back of your refrigerator. That is where you will find the timer valve. Reducing your water flow should help reduce the volume of water being let into your Ice Maker.
Jul 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
General Electric GSS22JET Side by Side Refrigerator Logo
185 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
