Question about Carrier 38CKC024 Air Conditioner
The unit will not start for the summer. It worked last summer.
I replaced the two fuses. I checked the breaker fuse in the service panel.
The fan in the furnace just blows air.
    Scholar:
  • 66 Answers
Open the control box and see if you have around 220-240V at the bottom of the contactor. The contactor is the switch looking thing in the bottom. If the unit is calling for air it should have a button in the middle that is pulled in. If you are not getting the volts at the contactor then you need to find the electrical problem.
If you have the correct voltage then look and see if the contactor is connected. The middle button should be pulled in. If you have one where you are unable to see the button, or it is not pulled in, Check the low voltage wiring. This is done by checking to see if there are 24V-28V on the side terminals of the contatcor. These terminals are located on the sides of the contactor. (some contactors have both sides of the 24V on one side.) Either way you should read 24-28V when checking across the two terminals. If you do not then you have a problem with the control wiring. (cut with weed eater, chewed by mouse etc.) I know the 24V coil is good because the inside unit is running. If the contactor is pulled in and the outdoor unit still does not run check and see if there is power at the other end of the contactor. (The end the switch breaks off)
If the switch is pulled in (or you read 24- 28V on the side of the contactor, and there is 240 V coming in on the line. Chances are you need to replace the contactor. Disconnect the power and pull one wire at a time of of the old contactor and install it on the new. After all of the wires are on the new one, remove the old contactor and throw it away. Screw the new contactor with all of the wires back onto the unit. restore power. Often times in our part of the country, there will be ants stuck in the points of the contactor. Just cleaning the contactor will buy more time.
Hope this helps.
Posted on Jul 11, 2010
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
I have a whirlpool central air conditioning and the condenser stoped working. what could I expect it to be?
When you say the 'condenser' stopped running - I'm 'assuming' you are talking about the outside unit, and I'm also 'assuming' that when you say it stopped running you mean 'nothing' runs on the outside unit - fan motor OR compressor. The fan motor will drown out the compressor running noise which is a 'low rumbling' sound - often not heard by the layman because of the noise the fan motor puts out.
Assuming you are talking about the outside unit and 'nothing' is running either fan motor or compressor then you might be 'in luck.' Because the most likely reason for the outside unit to be totally off will be a 'blown fuse' or a 'tripped breaker.' The good news is that in 'hot weather,' especially the kind of hot weather that has been present this summer (especially in the south) - blowing a fuse or tripping a breaker is not necessarily an expensive repair.
Indeed, it's not uncommon for a AC unit to blow a fuse (or trip a breaker) on occasion, although it must be noted that doing so is also is sign on something seriously wrong with your AC, i.e. a fan motor breaking down electrically or even a Compressor, both being expensive items to replace.
But, as I said, it's not uncommon for a fuse to blow once in awhile.
I would check my fuses (and breaker) and see if this is what has happened.
If you have fuses (usually located outside close to the condenser) and have no way to check them (you check them with a ohm meter looking for continuity) - then just 'replace' them with new ones. Note: always put 'time delay/dual element' fuses back in - even if the ones that are in there now are 'one time' fuses. 'Time delay' fuses do just what they say they will do - (they hold for just a second or two during that initial start up (of the compressor) without blowing).
If a blown fuse/tripped breaker is your problem then "most" of the time the AC will run ok and you will not have any more problems.
However, if after replacing the fuses and turning the AC back on - the fuse(s) blows instantly, or a short period thereafter (say a few minutes or an hour) then you probably have a problem that is causing it - i.e. the fan motor or compressor is going bad.
Note: one thing that you can fix that might be causing the fuse to blow is a dirty condenser. So, check the condenser coil (think of it like a car's radiator). It 'must' be clean to run properly and when it gets 'really dirty and clogged with dirt it will cause high head pressure and can cause the unit to blow fuses and trip breakers.
Good Luck!
Aug 10, 2011 | Whirlpool Heating & Cooling
My Sunbeam air conditioner has always flipped the breakers in my house (old wiring), but it worked fine for two summers and then sat last summer. This summer it blows the breaker constantly and in the...
This is a good question to ask. 1. if a unit trippes a breaker its for 2 reasons. A. to protect the wiring from catching fire . B. to protect you from electrical contact with ashort condition. Before you buy a new unit I would recommend you fix the wiring as bad siring is ******* the unit and costly to operate due to load resistance. Also replace any breakers that are unsed to support this unit. Brealers go bad esp if they have been problematic in the past. I am not certain as to the size of the unit you have now but if it cooled the room well then replace it with a match or a bit bigger unit.
As to why it tripps the breaker now? could be a couple thing Bad wiring like you state. weak breakers as I pointed out. or a bad compressor or fans. Or in my view its most like a combo of all the above. Hope this helps let me know.. Jon
Aug 03, 2011 | Kenmore 76129 Air Conditioner
Carrrier Central heat and air. Model 38CKC042300, Serial 4101E7590, Prosuct 38CKC042_ _ _301_ _. Woke up to hot house. Fan running but compressor outside isn't. Cool on flashing in thermostat window when I...
Unfortunately no, this is one of three things.
1. Compressor is worn and is starting to pull to many amps to operate. Can possibly be fixed by putting a hard start kit on the unit, but will have to be done by a technician.
2. Compressor has an internal short and will have to be replaced.
3. Fuses bad or under sized. Max fuse size is stated on information plate on outside unit.
Sorry to hear about your troubles and hope you can get it fixed soon!
Aug 15, 2010 | Carrier 38CKC042 Air Conditioner
Where is the fuse box?
Does the indoor unit run?
It sounds like you're looking in the right place. Check your power panel for a tripped circuit breaker (maybe more than one) or if the home is older, it may have fuses. It's possible that the outdoor disconnect also has fuses but that's not as likely. You can check around the outdoor unit and see if you smell anything burnt.
You can aso turn off the unit at the thermostat, wait a few minutes and see if the unit starts back up, but check the items listed above first.
Jul 17, 2010 | Goodman CKL42AR42 Air Conditioner
Outside fan not turning on.
Reset buttons (if applicable) are usually located near the brass service valves.
There is a circuit breaker in your electrical panel that furnishes voltage to your outdoor unit. This is a seperate circuit from the indoor unit.
Outdoor units should have a service disconnect mounted within 10-15 feet. This service disconnect may have fuses or a circuit breaker in it.
Usually if a fuse opens, you will not be able to tell from a visual inspection. It is best to take the fuse to your local hardware store where they can test it and offer a replacement if needed.
I hope you find this to be very helpful moving forward.
Apr 21, 2010 | Heating & Cooling
I have an american standard air cond. unit outside...I tried to turn it on yesterday and it comes on in the house but no cool air...on the outside the unit is not on, fans not turning etc. checked the...
You may have blown a fuse outside. If this happens a lot you may have something not wired correctly or a part going bad. This can be indicative of several different things. I would suggest calling a second company and see if they give you the same diagnosis.
Apr 26, 2009 | American Standard WCZ036F Air Conditioner
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
Carrier 38CKC024 Air Conditioner Logo
158 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
