Question about Matsonic MS8147C+ (N82E16813184008) Motherboard
Drivers I had a problem with blue screens from a bug which got into the system and removed all software and cleaned the hard drive ...haver now re loaded and all works fine but the sound and I have none. I therefore need to down load a Mircosoft sound driver for my XP pro or from Matsonic MS 8147c mother board ...I have been looking on Google for two days but can-not find a direct link to the required driver. Are you able to offer any assistance Nigel.
  • 1 more comment
  • Bestman Apr 21, 2008
    Hi Kgjsm397, Thank you for your assistance, and very quick reply, problem was fixed in no time using the details you advised.
    Great service. I now have some sound will have to find an amp to increase the amount of the sound as about half of what it was before,,but great to have some sound again.....Thanks Bestman.UK. .
  • Anonymous Sep 30, 2008
    drth
  • levenecartem Oct 03, 2008
    нужен драйвер... нужен... нужен... очень нужен!
  • 105 Answers
Http://www.driverguide.com/ go to this link and register your name you can down load driver for free
Posted on Apr 19, 2008
My Acer Aspire 5315-2122 laptop after welcome screen of windowsXp does not boot and blue screen shows ***stop:0x00000007B (0xF7a61528,0xc0000034,0x00000000,0x00000000) and does not go beyond
For BSOD follow the steps below that might can help:
Check the cables of VGA, Mouse , Printer , Scanner and Keyboard for loose coupling at the back of computer box.
Determine if you changed anything recently.
The most common cause of the Blue Screen is a recent change in your computer's settings or hardware. This is often related to new drivers getting installed or updated. Drivers are software that allow your hardware to communicate with Windows.
Check your computer's internal hardware. Sometimes, a poor connection inside the computer can cause a Blue Screen. Open your case and check to make sure that all the cables are firmly connected and that any cards are seated firmly in their sockets.
This is more difficult for laptops. You can check the hard drive and the RAM to make sure that they are connected properly. Remove the panels in the back that cover the hard drive and RAM with a small Phillips-head screwdriver. Press the components firmly into their connections. This step is not recommended due to damage in customer device risk.
Check your computer's temperature. Overheating can lead to your hardware malfunctioning. One of the most common components to overheat is the graphics card. In BIOS post test the computer shows on black screen at start up the temperature conditions of computer box. To check it customer can restart the computer and on first screen top right or left corner will show the information of temperature. If it is more than 40 celcius then it is more likely to crash the computer. Reseat the computer in a more cooler place i.e top of the table and away from the wall for venting purpose. The malfunction of processor fan can also be the reason.
Test your RAM. A common culprit in system crashes is a bad stick of RAM. When RAM fails, it causes the system to become unstable. Open the box unplug it from the Slot Remove the RAM clean it for carbon and dust particles and plug it back on make sure when you plug it back you hear the click sound.
Test your hard drive. Run the "chkdsk" function on your hard drive to scan for errors and fix potential problems. A failing hard drive can cause Blue Screens due to corrupted files. To run chkdsk, open command prompt and type CHKDSK entre.
Strip your computer down to the essentials. This is possible on desktop pcs that take out all hardware including hardisk, keyboard, mouse etc and start plugin them one by one until error comes again.
Oct 31, 2013 | Acer Aspire Computers & Internet
Diamond VC500 Capture Card Wont Record!?
Windows bugs... I would first remove the card and software and then reinstall. Update drivers under system devices. Try again. There may also be a menu to enable recording, allocate hard disc usage for recording etc.
Sep 05, 2012 | Diamond Multimedia ( VC500) Video Capture
What causes the blue screen and freezing?
The operating system is corrupted, this can be signs of a computer virus or malware.
Apr 05, 2012 | Dell Latitude D630 PC Notebook
Unmountable boot volume blue screen for a laptop dell d610. How can i fix problem?
Just reinstall the operation system form scratch ...if this is not a physical issue ..this will fix the problem ..You will have to have a boo-table disk with the operation system ..and all the drivers saved for it from the Dell support site ...just in case you do not have them on disk ..
If you have a operation system recovery partition or disk ..you may use it too...but remember that some recovery disks do not contain the operation system bu just the specific programs and drivers for the brand and model ..and it is logical why I wold go for a boot-able disk with the operation system ..and a clean install by booting from disk ...and also formatting the hard disk C partition during the installation process ..This way you will end up with a clean install ..and you will need to install all drivers..and programs you usually use....but you will be sure that all bugs are gone and the issue will not appear again..
If this is not a software problem ...it can also be caused by the ram memory being corrupted or the hard disk being issued...cause the blue screen is usually a memory fault ..and do not point the issue exactly ...can be from a missing file which will not let windows to boot up proper..pr ..from a virus that will interfere ..or from a issued ram memory unit ..or a hard disk with BADs on it ..
If reinstalling will not fix the problem you will have to take in mind the other factors of physical nature..
Nov 04, 2011 | Dell Latitude D610 Notebook
Blue Screen of Death
yeah unfortunitly you might have to reformat the entire hard drive and start from scratch
May 05, 2010 | Dell Dimension 3000 PC Desktop
Got a Acer 5420 that won't boot
First before replaceing the drive try to start in safe mode, if you can start it in safe mode do so with network support and go to malyware bytes and download their software to remove the bugs you have on the computer run disk cleanup and disk defragment as well, this is caused by some of the bugs that have come out. If it indeed is the drive out your in trouble if you have not backed it up, but post here to let me know and I will help you if I can, also please rate me if this helped.
Aug 12, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
I have a western digital external hard drive and im using the getbackdata software to try and recover about a 160gb of data. eventually the blue light goes out on the hard drive and software...
Your hard drive might be failing. Or it is possible that GetBackData might have a bug. Have you tried the latest version of the software? Try a different software to see if that helps.There are even some freeware data recovery softward utilities out there. Google for them.
May 19, 2009 | Western Digital Passport 320GB External...
Blue Screen
Sounds like Vista may be having a problem with hot-swapping the battery and optical drive. Do you have the latest BIOS for your system (A10)? Since it's a clean install - have you downloaded all updates, checked for updated drivers, etc.?
Dec 07, 2008 | Dell Latitude D620 Notebook
Matsonic MS8147C+ (N82E16813184008) Motherboard Logo
385 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
