Question about LG WM-2277HW Front Load Washer
Musty smell from washer
My LG washer/dryer are about 3-4 years old and now I have been noticing an awful smell from the washer. Obviously water pooling somewhere or detergent build up is causing mildew or something. The clothes do not smell fresh anymore and I have always looked after the machines by leaving the door open to air out, wipe inside down, making sure the rubber door seal is dry, etc. I got in the door seals with a cloth and cleaned out some gunk, also did a tub clean and and cleaned the filter, but nothing worked. Any advice? I spent a lot of money in these machines and am feeling disappointed. Model WM2477HS
SOURCE: LG washing machine has AWFUL mildew smell
I have tried several different things for my stinky LG washing machine that I just bought September 2007, including "remedies" from the customer service at LG - nothing worked for me. FINALLY, I HAVE DISCOVERED A SOLUTION AND AM SOOOO THANKFUL! I removed the liquid detergent tray and sprinkled baking soda (probably 2-3 tablespoons) where powdered detergent goes, and ran a cycle with hot water, no clothes, no detergent. This got rid of the smell, but the very next time I did a load of clothes with detergent, the stinky smell came back. So I tried adding baking soda in the same manner with every load of laundry I did (underneath the liquid detergent tray) and it has worked!!! With every load of laundry, I remove the liquid detergent tray and sprinkle approximately a tablespoon of baking soda and then replace the tray and fill it as normal with my liquid detergent (whatever is on sale, the brand of detergent has not made a difference for me). This is ALL I do. No leaving the door open, cleaning the rubber seal, wiping anything out. I believe the smell is a result of stuff we can't see or even get to and that's why the baking soda works.
I hope this helps someone else.
Posted on Nov 06, 2007
  • 145 Answers
SOURCE: musty mildew smell
It is the same with all the front load machines out there. I do a bleach load once a week and always leave the door unlatched. All washers always have some water left in them. You can also wipe the gasket down with a weak bleach and water mix on a rag it will help also.
Posted on Apr 18, 2008
  • 67 Answers
SOURCE: Mildew and Smells
It sounds like your drain from your washer has lint buid up,so when your machine is syphoning water back in the tuits only a small amount but when water sits on something and has air it turns black then into mold,clean your drain at your house,if you atill get this youll have to check your pump motor it has lint in it and has to be cleaned,also check your machine to see if it has a filter it could be clogged that will be in your owners manual,if this helps please vote me a fix ya
Posted on Jul 14, 2008
What is a P trap & why then didn't my old top-loader make my clothes smell? I think we've all been had.
Posted on Nov 02, 2008
  • 2976 Answers
SOURCE: Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Posted on Mar 18, 2009
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Why are the clothes coming out of the dryer smelling musty? we have the lg tromm dle5977w
The problem might not be with the dryer, but with the washer. Let me explain. When I first got my LG w/d set, I did a web search, and found that front load washers tend to build up bacteria and mold(which one person said was staining her clothes). The solution was to leave the door of the washer open when not in use. That worked for me for the most part, but the musty smell persisted. I found that the soap tray was getting dirty(from mold/bacteria), and the area inside was even worse. So now I remove the soap tray when not using the washer. Also, some appliance stores have cleaning packs that dissolve in an empty washer load. They are supposed to clean out residue and kill bacteria that cause odor in "HE" washers that may only be noticeable from the dryer. The brand name of the product I have is "Washer Fresh", and they're about $12 for 6 "PowerPacs".
May 06, 2010 | LG DLE2514 Electric Dryer
My LG dryer is about a year old and suddenly smells musty and mildewy inside! The washer is just fine (that seems to be the majority of complaints) but the DRYER definately smells. I clean the lint tray...
yes I have the same problem and can't find help anywhere...it smells like mold but my husband says like a dead animal and it gets smellier by the day. I leave the door open on both the washer
Jan 02, 2010 | LG Dryers
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Apr 21, 2009 | LG DLE2532W Electric Dryer
I have an LG washer that had the same problem. Go to the site www.nufreshnow.com and read all about why this is happening, how to fix it and how to keep it from comming back. A few different ways of cleaning the machine are explained.
The site sells a product that you may or may not need but the explanations are really good.
Nov 12, 2008 | Washing Machines
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty mildew smell
Apr 18, 2008 | LG WM2688HWM TROMM SteamWasher
Musty odor
Washer tub is probably very dirty from excess soap suds.  These washers have no way of cleaning rinsing themselves off so they will have to be disassembled and cleaned out to remove the odor.  That's about a 2 to 3 hour job.  Be sure to replace the rubber seal and the shaft seal to prevent leaks.
Oct 26, 2007 | LG WM2688HWM TROMM SteamWasher
LG WM-2277HW Front Load Washer Logo
112 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
