Question about Fellowes DM8C Cross-Cut Shredder
SHREDDER JAMMED ....SHUT OFF AND NOW WILL NOT WORK . bEFORE PROBLEM STARTED I WAS SHREDDING SOME ADDRESS LABELS .SELF STICKING ...DID THIS CAUSE THE PROBLEM AND IF SO CAN UNIT BE FIXED OR DO YOU THINK THE MOTOR IS SHOT....HELP SENIA JOHNSON
4 Suggested Answers
  • 168 Answers
SOURCE: Shredder Malfunction
Unless you are going to take the entire shredder apart, you are not going to be able to get to the blades unless you were going to pour some kind of liquid adhesive removal into the blades.
This wouldn't be my 1st suggestion.
One thing you can try is, go to your local hardware store and purchase a pint or quart of 3 in 1 household oil. With the machine UNPLUGGED. **** Also I would place some sheets of paper towels inside the catch bin to absorb any excess oil that drips out. **** Pour the 3 in 1 oil into the blades and let it soak in. I would start with about 2- 4 ounces, then wait about 10 minutes to allow the oil to soak into the labels. Plug the machine in and try running 1 single sheet through the shredder. With any luck, some of the labels will either stick to the paper or drop into the basket. You might have to do this about 3-5 times.
** Remember to UNPLUG the shredder each time you are pouring the 3 in 1 oil on to the blades just as a safety precaution.
I hope this helps.
Please let me know if it worked or not and also post a feedback / rating for me.
Have a good day.
Mac =)
Posted on Mar 15, 2008
  • 329 Answers
SOURCE: Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Posted on Jun 24, 2008
JayBlair
  • 328 Answers
SOURCE: Shredder Jams with more than 1 piece of paper thickness
I have seen paper shreds build up inside the cutter housing on this model. It grows into a big tumor inside and places a lot of resistance. You will have to take it apart and clean it thoroughly. Also, oiling the cutter asm.
Posted on Sep 07, 2009
Why doesn't forward shredding work?
  • The jam was not cleared completely
  • The shredding mechanism was damaged in the process of clearing he jam
Nov 28, 2015 | Royal 150MX Cross-Cut Shredder
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
My shredder is not working does it have a fuse somewhere
The shredder may be so clogged, with plastic for example, that the motor overheated and went into thermal shutdown. It also is possible that the input sensor is blocked. My experience with shredders that have been used to shred any type of plastic or plastic coated paper is that they are a complete mess inside.
Jul 22, 2014 | Universal UNV-48010 48010 Medium-Duty...
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
    Two possible problems;
    1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
    2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
    I hope this helps answer your problem. Best of luck!
    Greg
    Nov 12, 2009 | Royal 10X Shredder
    ROYAL RL170MX Shredder won't shred
    Did you ever put shredder oil onto the cutting blades?????
    The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
    Aug 11, 2009 | Royal 1280MX Shredder
    Motor not shutting off in Fellowes Powerhouse C-14 shredder
    this is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
    Dec 18, 2007 | Office Equipment & Supplies
    Fellowes DM8C Cross-Cut Shredder Logo
    Top Fellowes Office Equipment & Supplies Experts
    CheckitRight
    CheckitRight
    Jim Keysor
    Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
