Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
REFER IS WARM FREEZER IS FINE
REFER NOT COLD????
  • Kenmore Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorREFER IS WARM FREEZER IS FINE - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
Refer too warm freezer on the bottom is ok
You may have a problem with your solenoid valve and/or thermostat for the top refer.
Aug 09, 2014 | Amana Refrigerators
Why is the refer side of my 56612 warm while the freezer stays cold
The freezer is not defrosting and has frozen over. Once it is defrosted right the fridge will work fine again
Nov 26, 2013 | Refrigerators
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
New amana refer worked when first plugged in, blew out really cold air, checked again in about five hours,warm air. warm air since.
Yes it is ok.... you need to actually create heat to create cold... It's the law of thermodynamics... refrigeration is actually the removal of heat not the creation of cold... pretty deep huh?!
Jul 24, 2011 | Amana ATB1832AR Top Freezer Refrigerator
I have an amana ASD2626hes side by side refer/freezer unti. REcently it soppted colling in the refer and the freezer was cold on the bottom only - top warm. I pulled the freezer inside coer - found the...
It could be either....
It is best to check and see if you are getting power to the fan...power to fan, the fan is bad...no power the board is bad...
heatman101
Apr 23, 2011 | Amana Refrigerators
Has stopped cooling
IF THE FREZERWORKS THE ISSUE IS THE SETING FOR THE AIRFLOW BETWEEN THE FREEZER AND REFER BOX IS SET TO MAX COLD FREEZER, IT HAPPENS MORE THAN YOU WOULD THINK! IF IT SEEMS WARM, RATHER THAN SETTING THE THERMOSTAT TO COLDER THEY ALSO PEG THE OTHER CONTROL THAT DOES NOT CONTROL THE COMPRESSOR AT ALL IT SIMPLY OPENS A FLAPPER TRAP DOOR AJAR OR WIDE OPEN OR IF SET TO MAX COLD IT CLOSES OFF THE REEFER!! AND KEEPS THE COLD IN THE FREEZER BOX, IF THE FREEZER WORKS ITS FINE !
Apr 23, 2010 | GE Profile PSS26NGS Side by Side...
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
I have a indest fridge freezer and the fridge is warm but the freezer is cold.what could be the problem?
Your probably having a defrost problem. if the evaporator gets iced up it doesn't allow the cold air from the freezer to the refer section. A good place to start is the defrost thermostat on the heater.
Jun 13, 2008 | Refrigerators
Freezing fine,food area warm
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
