Question about Philips VR620CAT VCR
Error 2 on Front Panel
This VCR keeps powering down and the tape will not eject. I went ahead and manually removed the tape but the unit still powers down and flashes the number 2 on the front panel.....what's wrong? Can it be fixed or should I just go ahead and retire it?
  • j12251225 Dec 25, 2008
    I have the exact same problem.
  • PositiveOne Apr 04, 2009
    Thanks for the help.....there was no debris or anything found in the unit to make it perform the way it did.....I just use it as a "go between" for my X Box, just need the use of the video output/input. Once again, thanks again!!!
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Posted on Dec 25, 2008
Have a samsung DVD-V1000 VCR/DVD combo unit. DVD player works fine. been experiencing gradual decline of the VCR and now it won't play at all. will **** tape into the machine but can't get it out. any...
Always frustrating when a videotape gets stuck in a failing/failed VCR deck. Since all decks use a loading motor and gear system, it would be a simple matter of gaining access to the terminal pins of the loading motor (assuming you can see these from the top of the deck) and applying 9V DC voltage to 'unwind' the loading mechanism - you may get a little bit of tape outside of the cassette, but at least it's ejected. If the DVD deck works as you say, you may be able to continue using this for a while.
If the loading assembly is toward the underside of the main deck, you may need to remove the entire VCR mechanism - then you can apply the 9V to the motor to unwind the gear (it is easier to apply a low voltage to the deck rather than use physical force to unwind gears - as you may damage them) - while leaving the DVD deck in the unit untouched. There should be 2 separate mechanisms in this combo - 1 being for DVD the other being for VCR - as long as you are careful when removing the VCR deck, you should have no problem retrieving your tape (with maybe a little creasing but otherwise undamaged) from it. Be careful when removing the top cover and front panel assembly; you don't want anything broken.
Since VCRs are becoming obsolete these days, it is hardly worth getting this one repaired by any service centre (unless you want to pay a fortune, which is usually more than the retail price of a new combo unit). It's up to you.
NOTE: you cannot operate this unit with the VCR deck disconnected from the motherboard (you will get an annoying error display with the VCR removed). Once you have successfully removed your tape from it, reconnect the VCR mechanism to the board - but do not use it - just use the DVD part if that is still OK. Refit the covers, plug machine into power. Done!
You need a lot of patience to undertake the abovementioned action. Fingers crossed.
Mar 28, 2011 | Samsung DVD-V1000 DVD Player/VCR
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Will not eject cassett
try this unplug and then keep finger on eject and plug back in keeping hold of eject if not work then
UNPLUG and take top off video and you will see were the tape is stuck THERE WILL BE A RUBBER BELT ON ONE SIDE OF MECHANISM TURN COGS THAT BELT ARE ON ( USELY ANT-CLOCK ) takes time you will see parts move towards front of video ( IF NOT CHANGE THE DIRECTION TURNING ) the tape will come out when finished
THEN PLUG IN SO VIDEO CAN RESET MECHANISM
Nov 08, 2009 | Cell Phones
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
RCA DVD/VCR model DRC8320
Interface error
(and or)
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Eject error
the vcr needs to be unplugged and left for about a day to reset itself.then plugged in back this will adjust the error.
Apr 04, 2007 | Emerson EWV403 VHS VCR
TV shuts off when VCR tries to eject cassette
This is a hard call man. Some combos have to be laid down when taking the back off or it will collapse when you do take off the back, falling over backwards as they are top heavy. These units are so tight inside by means of no room to work so alot of maufacturers have extension cables to attach to componets ie vcr deck and main chassis. After they take them apart. If you really feel confident then lay the set down on its face and take off the back and after the back is off look to see in the deck part if the tape has come out of the cassette or if it all looks normal. If you see the tape out of the cassette ,cut off the tape on both sides and see if the tape will eject. It it does then go back in after and remove the remainder of the old tape. Now it could have been a bad tape but most likly something is wrong with the mechanism. If you cant see anything out of norm, dont try to force the tape out as you WILL cause more damage and most likely unrepairable. Really there are no user serviceable parts inside these buggers so the best advise I can give ya is to disconnect the thing and take it into your repair shop for an estimate!! Good Luck
May 23, 2006 | Samsung CXJ1964 19 in. TV/VCR Combo
Open Questions:
See all Philips VR620CAT VCR Questions
Philips VR620CAT VCR Logo
583 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
