Ok i have a real digital tv with dvd player iam aslo connected to a direct tv box and the tv is set on aux 1 now when i try to change channels i go to dvd mode and the remote doesn't work to turn tv on or off or change channels
  • 6,993 Answers
does the buttons on the TV work? I mean the Channel, volume and menu buttons?
If the buttons on the TV is working, then it means the fault is either from the remote or the remote sensor.
let me know if the buttons on the TV is working, so that I can know what to do.
I look forward to your reply.
Bye for now.
Posted on Jul 19, 2010
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
Snowy screen when I play a DVD
hi!!!!
try to change the cable!!!
may that helpS :)
Sep 27, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
When I switch the TV on I just get a message 'No Signal' ,this also happens when I try to play a DVD. The TV is on and I just get a blue blank screen. The other TVs in the house that are all...
You might be on the wrong "channel" on your TV. On the remote for your TV, there should be a set of buttons for if you want the remote to control the TV, or DVD player, or Aux 1 or 2. You want to click the TV button and try changing the TV's "channel". Your cable/DVD player are on different "channels" of the TV. Try scrolling up and down through the "channels" of your TV.
May 25, 2011 | Bush 5693D 24" TV
I have rca STB7766G1 converter box can I connect my dvd player
Trial and error. There is no list of products that will work together and how, so when you have situations that come up such as these you have to connect the electronic devices and see what happens. What's worse is that the combination will not always work with the same brands and even if you do get this to work today it might not work tomorrow.
Ok connect the DVD player to the television. Where it says out on the DVD player you connect the connecting cables either yellow, white, and red or green, blue, red, white, red. You connect the other end of them to the television. Put the television on the correct input. Try playing a movie to make sure the dvd player and television are connected properly.
Ok now where it says IN on the DVD player. Connect a yellow, red, and white cable. The other end of that cable connects to the converter box where it says out.
You can also connect the converter box and the dvd player in this way if applicable. If the dvd player has an RF (coax) IN connect a coaxial cable there and connect it to where it says OUT on the converter box.
Then you connect an antenna to where it says ANTENNA IN on the converter box. Now you will have to be able to put your dvd player in input (aux) or turn it to channel 3. You will always leave your dvd player in input (aux) or on channel 3. You will only change channels on the converter box with its remote control or the buttons directly on it. Good luck!
Apr 23, 2011 | Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Sound interuptions with Samsung S4253
My set started having sound issues recently. Every now and then, randomly, I get a split second, static sound. It sounds like an old record player when it skips. It happens on all channels HD and digital. Also happens when I'm watching a DVD. This leads me to think that it's not my cable box (Dish Network). I have a Bose 321 aux amp plugged in. I hear it through my aux speakers, as well as directly through the tv set. Not sure what to do. Is it possible my tv's amp is burning out? What could be causing this?
Mar 28, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
