Question about Brother LS2020 Sewing Machine
Shank for my brother ls 2020
I lost the shank for my brother ls 2020 where can I get another one cheap?
  • 980 Answers
Any Brother dealer, they are very cheap anyway
Posted on Jul 14, 2010
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Dec 31, 2016 | Brother Sewing Machines
Will an embroidery unit for a brother v31 fit an se400?
You may need a shank adapter. Most dealers have them available.
Jan 31, 2015 | Brother LS-2125 Mechanical Sewing Machine
I lost the screw for the shank on my ls 2125 where can I get a replacement?
parts can be had... Call your local dealer and tell him what you need. It should be pretty standard but they would know what to give you. Or call brother direct.
Aug 25, 2012 | Brother LS-2125 Mechanical Sewing Machine
After cleaning my LS-2020 sewing machine, it now won't make stitches even though bobbin is in and threaded right.
Please check that the needle is in the right way, flat shank to the back and all the way up into the housing. This would cause the stitches to not form.
Failing that, if it is not picking up the bottom thread, then the timing could be out and it would need to visit the shop.
May 21, 2011 | Sewing Machines
Where to buy a foot control and power cord for model ls-2020
you can go to www.sewingpartsonline.com and order one through them, they are pretty much the same for there LS models. Or you can call Brother at 1-877-276-8437 and order directly from them
Jan 02, 2011 | Brother LS2020 Sewing Machine
I have a Brother LS 15 sewing machine
raise presser foot to highest level pulling wheel toward you(counterclockwise) release the foot assembly with the lever at the back of the foot holder assembly place you quilting foot in line with the slot on the shank lower the presser foot lever on the shank if it is where it should be the bar will snap in and you should hear an audiable click or snap let me know if this helps
thanks amy
May 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
Attaching walking foot
you probably purchased the incorrect walking foot for your specific machine. check and make sure if you have a high shank or a low shank....the way to determine if you have a low-shank is to measure the screw from the plate and look at the distance if it is 5/8 then you have a low, any higher about 1in. then you have a high shank, so you would purchase a foot depending on your shank.
Mar 20, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS2020 Sewing Machine Logo
65 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
