Question about Daewoo Televison & Video
Disc error on daewoo dqr 1000d when playing dvds
3 Suggested Answers
  • 111 Answers
SOURCE: Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Posted on Apr 01, 2010
walesarumi
  • 6993 Answers
SOURCE: my dvd player plays cds but wont play dvds says
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Posted on Apr 22, 2010
How to remove disc error message for my lg ht303su-a2 dvd cd player because it plays some dvds and other dvds wont play
Check a CD. If it plays, the Optical Pickup for the DVD is worn out and will need to be replaced.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 22, 2014 | LG HT303SU Theater System
Kenwood kvt-911dvd disc error for dvd play?
you just bought it? take it back it may be a rare case of Dead on arrival.
Jun 10, 2008 | Car Audio & Video
Iview 2600hd dvd player has error "this player is incompatible with the region marking of this disc"
DVDs are coded for different areas of the world. If you bought the DVD from an online source it may not play on your format of DVD player.
Jan 24, 2013 | Iview 2600HD 5.1-CH Digital HDMI...
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Daewoo VHS to DVD converter - disk only plays on the converter
The Disc needs to be finalised. Using the setup menu and disc info you select "finalize disc". I had the same problem.
Jan 12, 2009 | Daewoo DV-T8DN VHS VCR
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
Daewoo DV-6T955B DVD Player Problem
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
Nexxtec N700
hi my father had the same problem and it turns out his dvd player wuld only play -dvds so check your dvds and see but sometimes a more expensive model will only play original dvds and not copies
good luck
Nov 10, 2007 | NexxTech N600D DVD Player
Televison & Video Logo
63 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
