Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
We installed the EJ500 about 3 years ago. Recently the timer display is blank. So I changed the batteries. That seems to fix the problem for about 2 months. Now we have the same problem again...the display is blank and the timer does not work at all! Any ideas?
Http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
The EJ500 comes with a 1 year limited warranty. It may be time for a new timer.
Buy at:
http://www.aplussupply.com/intermatic/timer.htm
Posted on Sep 26, 2010
I have two Orbit 62056 timers display not working, new fresh batteries installed.
After four years of service, the displays may have simply failed although failure of both at the same time seems a bit of a coincidence.
Feb 22, 2015 | Orbit 62056 1-Port, Single Dial Hose...
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
http://waterheatertimer.org/Aube-timers-and-manuals.html
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 28, 2012 | Hardware & Accessories
No digital display, does that mean the battery is dead
You posted under Intermatic ST01C timer.
Display on this timer goes blank when new CR2 battery is needed and when timer has gone bad.
Many times when a new battery is installed, the timer has to be reset and then reprogrammed.
If timer cannot be reprogrammed after battery install, then timer has gone bad.
Open following links for ST01C resources: ez programming and reset instructions.
http://waterheatertimer.org/images/ST01C-battery-tray-0-400.jpg
http://waterheatertimer.org/ST01C-program.html
Jul 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
We had a aube timer for years and we changed the outside poll light with a new top somehow when we screwed in the post lamp we hit one of the wires and when i went to turn it on the breaker flipped after...
Aube/Honeywell timers have internal rechargeable battery that powers the display.
Battery is not replaceable. Plus the electronics inside timers are susceptible to power surge.
Without the display, timer cannot be used.
These timers come with standard 1 year limited warranty.
http://waterheatertimer.org/Aube-timers.html
Jul 10, 2011 | Aube Technologies Aube 7-Day Programmable...
My ST01c unit is stuck on MANual and I can't get to the SETUP option.
The timer initializes in MANual mode.
To reach SET UP, press MODE button until set-up displays.
If MODE button does not work, then timer has a serious glitch.
1) If this is a timer that worked correctly before, and recently malfunctioned, then try replacing CR2 battery. The timer display and programming functions are dependent on the battery, so when battery starts going dead, the timer does odd things.
http://waterheatertimer.org/ST01C-program.html#battery
2) Try resetting timer.
Hold down ON-OFF button and then push reset button for two seconds.
Release Reset button, but keep holding ON-OFF button until display flashes INIT.
Then release ON-OFF button and 12:00 displays.
Following page has easy to follow programming steps:
3) ST01C has 1 year limited warranty, and people write in about defective timers each day.
There are no repair parts other than the battery.
Manual says when all other attempts fail, then reset timer as described above.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
4) If this is new timer, then exchange defective timer for new timer.
I test timers: 4-6% arrive defective. Many go bad first year or two. Some last quite a while.
Some programmable timers can be reset and the timer recovers, as described above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
We recently purchased a home with an intermatic model EJ500 timer. It does not work. Changed batteries - screen does not light up. Breaker checked and working. Nothing happens when press next/on/off and...
EJ500 has 1 year warranty. The reset button sits naturally lower than other buttons.
The manual shows troubleshooting.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
If timer is blank: display bulb burned out; press next/on/off, other timer or switch has turned off power to EJ500.
Maybe a new timer is needed. ST01C (1 year) & EI600 (5 year warranty) each offer same 40-programs per week.
Timers shown above are battery operated, and cannot operate load farther than 100' from timer.
EI500 & GE 15086 offer 7 programs per week ... 7 on events and 7 off events.
http://waterheatertimer.org/Programmable.html#progr
Aug 03, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I have a GE 7-Day in-wall Programmable Digital Timer Model # 15086 which I installed about a year ago and was working fine until a few days ago. The screen went blank and the unit does not work. It acts...
The battery is not easily replaceable. It's a 1.2 volt, 80ma Nickel-metal hydride battery, that is soldered to the circuit board. I opened the back of the switch to find the battery. The one in this switch was in bad shape. It looks like the battery broke apart, but wasn't leaking. The switch is less then a year old. Bad design.
I just opened this up today and am going to look for a replacement battery. But soldering will obviously be involved to get the a new battery back in place.
Jul 30, 2010 | GE Hardware & Accessories
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
595 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
