Question about Kenmore 62602 Electric Dryer
Pulley broke off
Where can i get a copy of the manual for model #110.64622000 electric kenmore dryer
  • 78 Answers
CALL SEARS AND THEY CAN GET YOU ONE, THKS LARRY
Posted on Jul 12, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Need manual for kenmore electric dryer Model # C85072
Go to Kenmore's website, and click their HELP section and ask them how to get a copy of the manual. Otherwise, I would suggest searching YOUTUBE to see if anyone has posted one.
Aug 08, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore elite front load dryer has power but won't turn on. It beeps once like OT is going to start but nothing
check to see if the belt broke,there's a switch on the belt pulley on some models,if the belt snaps from to large a load the pulley doesn't have any tension on it and the switch opens so the dryer won't run.when you put the belt back on the pulley sets the switch so power will go tough it again and the dryer will run,also check the door switch,if someone shut the door to hard and broke the switch the dryer won't run.these are the easy things to check without needing a meter.hopeit helps,if you're in mass. and need a tech you can call peter de's appliance 781-438-9442 very good techs
Jan 26, 2014 | Kenmore Dryers
Kenmore dryer model 110.63112100 drum does not turn
Check both of your circuit breakers if the dryer is electric. Though the heating elements are 240v, the motor and electrics are 120v and connect to only 1 side of the plug. The breaker for that side may have tripped.
When you press the start button on the dryer, are you able to hear a motor turning (humming) faintly? If you can, and the drum doesn't turn, this is an indication that the belt has broken, jumped off its track, or the tensioner / idler pulley is either broke or skipped over the belt.
Jul 01, 2010 | Kenmore Dryers
Idler pulley came loose and I need schematic so I can put it tog
the idler pulley fell out of its slot or it broke into pieces
if it just fell out of the slot you should take out the drum and just kind of play with it  depending on the dryer if you gave me your model i can take a look  and i dont know what kind of idler pulley you have so i am not much help AT ALL without it i;m sorry
Jun 08, 2009 | Kenmore 62622 Electric Dryer
I need to change the electrical cord from a four wire to a 3 wire and i want to make sure i do it rite. i do not have a manual. its a kenmore 80 series electric dryer 220v model #11062812101
You can find a copy of the installation manual at managemyhome.com.It describes how to connect as 4 or 3 wire.
Enter your model number (I had to delete the last digit), and make sure you enter Kenmore in all capital letters.
Feb 03, 2009 | Kenmore 62872 Electric Dryer
I have a Kenmore Series 80 dryer and the belt broke. The pulley came off and I don't know where it goes or how to put it back on. I also don't know the routing diagram for the new belt. Please help ASAP I...
it goes on the shaft of the electric motor the belt goes around the drum should be a set screw on pulley reattach to shaft tighten then looosen bracket on motor apply tension and tighten you may have to go to the hardware st ore and get another screw if yours is lost as a tip apply red loctite to the threads to prevent it from vibrating loose they have that at the hardware store or auto store
Jan 15, 2009 | Kenmore 62622 Electric Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
