Question about Maytag MSD2732GR Side by Side Refrigerator
Ice Maker The ice in the despenser is a block of ice. Not all the ice just below the ice maker. What could be the problem? Water in the front door works.
  • urimg Jul 04, 2008
    I have the same problem...it seems the ice maker is leaking and making a block of ice and wraps the dispenser in a block of ice...is there a solution to this??? It's only dripping small drops of water.
  • Anonymous Mar 27, 2014
    My ice maker works ok but the little door in the door where the ice comes out does not close all the way causing warm air to enter the freezer. There is no ice blocking it . Is there a spring or magnet that closes this door after the ice comes out and how do I fix it?
Ice Freezs in storage tray
Posted on May 16, 2008
Kenmore 106.56666500 ice maker not working
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not despensing ice
Make sure the ice bin is pushed all the way in position. Also make sure you don't have a big clump of frozen ice blocking the auger and keeping it from working.
It is a good idea once in a while to take the ice bin out and completely wash and clean it out real good.
Jul 20, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker is not getting water to make cubes.
The red light should flash, the most likely suspect is that the inlet tube that carries the water to the ice maker is frozen. If you open the freezer door and hold the swinging door in front of the ice maker up you will see a black rubber tube coming down from the top. If it feels hard it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or unplug it, warm up the tube with a hair dryer or for quicker unthawing take a turkey baster and squirt hot water into the tube catching the run off with a towel.
It can take quite some time and several cups of hot water to finally clear the ice. Once done it will take about 2 hours for the ice maker to cool back down and start a cycle to test it.
Apr 18, 2010 | Whirlpool GD5SHAX Side by Side...
I have a side by side that has the ice maker in the door, when it makes ice cubes, they come out all connected and this makes it difficult to get ice to despense from the shoot and most of the time it will...
It sounds like you have too large a fill of water in the ice maker. If you remove the ice maker there is a fill adjustment screw under the cover of the ice maker.( the only way to get the cover off is to remove the ice maker)
Very small plastic screw head of about 1/8 inch or less. Ice maker controls water valve by time fill. Believe there is one turn adjustment total available. You might want to put a small hole in the cover before you reinstall it to adjust screw the next time without removing ice maker, believe it will be side facing out. Lastly I think you turn adjustment screw in to decrease and out to increase time of fill.
Suggest leaving a towel on the floor for awhile until you have solved problem.
Next thing to try would be a different ice maker, or if normal sized ice is melting and refreezing in the bin, you have a cooling or thermostat problem .
Good luck
Mar 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
The flap on the ice despenser is not closing and water is forming in the pan below. Is there an scamatic of the door ice maker despenser?
If you can look up and see the flap is loose or sloppy, you need one of these two kits. Kit # 8201649 is the chute door, door bracket, spring, damper pot.
Kit # 8201756 contains all the above plus a metal bracket designed to replace the housing bracket, the door pivot pin and a metal brace.
May 10, 2009 | Whirlpool ED2FHEXM Side by Side...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2732GR Side by Side Refrigerator Logo
133 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
