Question about Acomdata 250GB External Firewire HD 250 GB FireWire 400 (1394a) Hard Drive
Acomdata HD320FE5-72 disassembly
How do i take apart the enclosure
5 Suggested Answers
zzptichka
  • 95 Answers
SOURCE: Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Posted on Nov 03, 2008
Chinthakaj
  • 416 Answers
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
Posted on Feb 02, 2009
  • 3 Answers
SOURCE: acomdata HD500uhe5-72 cant be seen . on XP
Try rebooting the computer first with the drive not connected to it.
After the computer reboots, make sure the accomdata is turned off then connect the usb cable. Then turn it on and you should get the password dialog box and be able to access it.
Posted on Apr 21, 2009
  • 109 Answers
SOURCE: Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Posted on Feb 06, 2010
My external hard drive fell off my desk and since it has been beeping and not operating correctly
You broke it. Does the Acomdata warranty cover self-inflicted damage?
Did you buy it with a credit-card that adds "all-perils" insurance?
All you can do is to disassemble the enclosure, remove the disk-drive,
buy a similar, compatible, disk-drive, install it into the enclosure,
and thus "revive" your external storage device.
Nov 02, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Red and blue light alternately blinking. What can i do.
Remove the drive from the enclosure and either install it in your machine as a slave or you will need to buy a new enclosure and put the drive in it.
Sep 17, 2009 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Flashing red/blue acomdata 1 terrabyte external hard drive. computer won't recognize
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 06, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Problems with Hard Drive
Appreciate the direct "Ask Me".
T your concern:
  • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
  • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
  • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
  • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
  • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
  • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
  • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
  • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
  • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
  • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
  • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
  • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My computer has ceased to recognize the drive.
this is cont. from my post on the previous issue.
I went as far as reloading windows on my pc to see if the problem was my pc did not help.
I now have a 500GB exteranl hard drive the pc is working fine with it so I know the problem is in the acomdata drive.
I think the key is a different manufacturer it so far is working fine.
I am bummed out the acomdata only lasted about 2 to 3 weeks before I had a problem or noticed i had a problem. Should I try to format the drive would this help?
Apr 05, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
External hard drive will not turn on
Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
Keep me posted.
Oct 08, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata 250GB External Firewire HD 250 GB FireWire 400 (1394a) Hard Drive Logo
277 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
