Question about Sylvania SSC192 19 Inch Tv/vcr Combo Monitor
I would like to be able to program a Sylvania SSC192 TV/VCR combo with a cable remote - but need the code (the remote is an Atlas OCAP 5-Device).
  • 10,515 Answers
Try codes :-
0675, 0821, 1268, 0054, 0030, 0171, 0020, 0028, 0065, 0096, 0381, 1271, 1944,1963, 0171, 1271, 0675, 1781, 0035, 0081, 0000, 0043,
0110, 0593, 1593
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 11, 2010
  • cgrapski Jul 11, 2010
    Hi, Thanks for the very quick response. Unfortunately none of these worked. But I am not sure if there is anything else you might be able to suggest trying.
    I do want to give you some information in case it is useful for you.
    Here are the codes you provided. I will break them into two groups - one that the cable remote (Atlas) gave as options (although I tried them again I didn't record the details (and I don't know if this is of any help to you - but if you'd like I can add this for those codes. I do believe the first two in the list (but perhaps one or two more) gave the "long" single light indicating it wasn't appropriate. The rest giving the double blink saying it was POTENTIALLY so. But I will indicate those that gave the DOUBLE blink in the rest of your list (if this helps you in the future). You provided me a few codes all of my searching found but most of what you provided not in the remote manual are the first time I had these, and so it was at least helpful in that you were able to give me further possibilities that may have worked). The codes in the remote manual are between the square brackets "[]" and the rest were ones you added beyond that. The BOLD ones gave the DOUBLE CLICK (indicating that they were potential).
    One further point - I was able to locate the original remote (which I was told was broken and discarded) and have gotten it working. So at minimum there is now the ability to control the volume but with the hassle of having to use a second remote for that. {But at least I don't now have to replace the remote - the cheapest I could find was $25}. And also this shows that the remote works. [I have some general questions you may be able to answer for me at the end - as I try and understand why it is so difficult to get this to work. But here is the info for your files if it may be of any value - again the BOLD are "potential" whereas the others the remote gives a "long blink" which it says indicates it is invalid.
    0675, 0821, 1268, [ 0054, 0030, 0171, 0020, 0028, 0065, 0096, 0381, 1271,
    1944,1963 ], 0171, 1271, 0675, 1781, 0035, 0081, 0000, 0043,
    0110,
    0593, 1593
    I don't know if that gives you any help that might discover the code for answering my question (and if it does I'll give you the differences of those within the brackets - or if you'd like it anyway I'll send it to you if it can assist you in the future).
    But please let me know any other OPTIONS I may have.
    Here is my second related question. First, the remote DOES have a possibility to "discover" the code but that means going through its whole range to see if you can discover it - I actually used that successfully on another TV and found the code within a few tries. I tried on this one (my mother's) and was pushing the button for a long time with no luck - but realize there are probably as many as 2000 possibilities (given the codes provided), and unfortunately, although I asked her to keep pushing the button until the TV turned off - she stopped long before exhausting the options.
    So at minimum one question, if you are unable to find any other possible codes, is whether it is worth going through that effort - (and perhaps, and this will relate to the next general question for my edification and understanding, you can inform me of HOW MANY possibilities the remote will try (to give me an idea of how long I should try that before realizing it is futile to continue). But this leads to the more general question about how these things "work" in general.
    The question is this: Am I correct that all INFRARED remotes basically utilize a particular unique FREQUENCY? And if so - then would it not also be correct that there would therefore necessarily be SOME code that would work? (And thus - would my going through the whole range on the remote's self-discovering mode be worth trying? Essentially does the remote itself, when doing this, try ALL possibilities (or is it limited in its range - and thus potentially a unit's code/frequency would not be available to that universal remote?) or just a particular set it is programmed with?
    So I am asking also in general is there always going to be SOME code that WILL work (its just discovering what it is?)
    Or are there different varieties of infrared systems used for remotes - and thus that Remote X and Component Y will never be able to be used together? It not being an issue of programming the right frequency but some other aspect of how it either sends (the remote) or receives (the component) the signal? That doesn't seem to me as likely - adding complexity to such a simple system and concept - but you never know.
    Please let me know any other possible options to try, if any, and also if you don't mind educating me on how these systems work (it seems to me, intuitively, simple enough (the simple frequency correlation between remote and receiver) - but that is just my intuition.
    And thanks again for the quick response. This is the first I have tried this service and I am pleased to see its potential.
    Charlie
    Sorry if this is redundant - but as I am new to this service - I want to make sure my "response" question was received. I am not sure how it would show up if there is a response. The form was a bit confusing when I submitted the last part.
Can Atlas Ocap 5 control Sansui TV/DVD combo? If yes, what code does it need?
You have this backwards. The Atlas Ocap 5, if programmable, contains a library of codes, one or more of which can control your Sansui. There may be a search feature you can use to find what works.
May 13, 2014 | Sansui Televison & Video
I have an Atlas Ocap remote, need a control code for a Dynex Blu ray player
Hello
Blu-Ray payers cannot be operated by universal remote controls.
Mar 17, 2012 | Televison & Video
Looking for code for my sylvania tv for my one for all access 4 u remote
Hello
Universal remote codes for Sylvania TV with One for all URC - 3300 remote control are:
0054, 0030, 0171
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
Jul 13, 2011 | One For All URC-3300 Remote Control
I need the remote contol code for a sylvania 6313cb 13in. tv/vcr combo
Hello
Universal remote code for Sylvania TV/VCR Combo is:
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 31, 2011 | Sylvania 6313CB 13 in. TV/VCR Combo
Im looking for codes for a sylvania tv
The codes to try for Sylvania TVs are 0054 0030 0171.
The manual and codes are available from the One For All support site: http://www.oneforall-na.com/remote.php?type=URC%203021 . The link for codes is at the bottom right of the page.
However, most remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, then you may need to get a newer remote.
I hope this helps.
Feb 25, 2011 | One For All URC-3021 Remote Control
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Computers & Internet Logo
55 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
