I have not drivers (installation disk is corrupted) for stereo bluetooth HEADSET Plantronics Pulsar 590. My system is vista.
    Brigadier General:
  • 7,191 Answers
To get the installation drivers or a replacement installation disk, kindly contact the manufacturer's customer support section by clicking this link:
http://www.plantronics.com/north_america/en_US/support/
On the page which opens, you will find the telephone numbers and also the email option to contact the customer support.
Thanks for using FixYa.
Posted on Jul 11, 2010
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Good luck from Headsets Direct!
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
Cant get the pulsar 590 works with windows 7
I finally solved this problem. Buy a CSR v4.0 enabled bluetooth dongle on ebay, plug it in to a usb slot. Right click the bluetooth icon in system tray and select "Settings" and tick "Allow bluetooth devices to find this computer." Then click "add a device", turn on your bluetooth headphones and the headphones will show up in bluetooth devices. Add the device, then right click your speaker icon in the system tray, select playback devices. From the menu, select the headphones and set them as default. I did this and they work perfectly. Furthermore when I turn the headphones off, the sound goes back to normal speakers - no other adjustments made. Turn the headphones on again and the sound defaults to them. I noticed on an earlier failed install of the headphones when they did appear in Devices and Printers that the drivers were CSR something enabled. I did try some cheaper dongles and the actual Plantronics USB dongle(expensive) to no avail. Get a CSR 4.0 enabled device. Mine cost 6.00AU total.a199a342-df05-4c7a-89f7-c82a948f31c9.jpg
Feb 21, 2011 | Plantronics Pulsar 590A Wireless Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I have't drivers for stereo bluetooth headset Pulsar 590
HI. You will need to privately request this driver. click the link below to be directed to the request page. Most of the information will be filled out for you. Just fill out the rest and click the send button on the bottom. Your drivers will be sent to your e-mail box. Open the email and click on the link or attachment to download and install your driver package. CLICK HERE
NOTE_ The driver e mail may be sent to your spam folder, so watch for that.
Jul 11, 2010 | Computers & Internet
How to Replace the Battery of 590 plantronics?
17 jun 2010
Thank you safauoc! I am going to look into the matter of replacing the battery on the now discontinued and very expensive Plantronics 590a.
753f191.jpg It came as a very big disappointment to learn that this headset is not compliant with Bluetooth V2.0 and the Blutooth Handsfree Profile. To get it to work with Skype, I had to purchase the Plantronics BUA-100 dongle - which was also very very expensive.
883c841.jpg Now the battery is evidently failing - and the 590a's range is getting shorter and shorter.
I do not think that Plantronics has managed this device's roll-out in a competant manner.
Jan 09, 2010 | Plantronics Pulsar 590A Wireless Headset
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Winamp/bluetooth/plantronics p590
I have found that winamp doesn't automatically output through any hands-free headphones, therefore you need to go into Preferences on Winamp (Ctrl+P), go to:
-Plugins/Output
-select Nullsoft DirectSound Output -->configure
-select Device tab
-select 02: Bluetooth Hands-Free Audio
-click apply
If music is already playing, click STOP then PLAY, pause will not do it.
I have been looking for this fix all day on the internet, but finally worked it out myself.
Hopefully this post will make someone else's day less stressful!
Nov 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
How do I listen to Itunes from my MacBook Pro on plantronics p590 headset
http://macapper.com/2007/10/31/hidden-leopard-gem-stereo-bluetooth-support/
Jul 29, 2008 | Plantronics Pulsar 590A Wireless Headset
Settin up bluetooth
Turn headset off.
Hold down the "phone" button on the headset.
Turn headset on.
Release "phone" button.
LED ring should be alternately flashing red/blue.
Voila.
Jun 21, 2008 | Plantronics Pulsar 590A Wireless Headset
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
