Question about Coleman Air Tools & Compressors
Electric Motor running slow
I have a Coleman Powermate Professional Compressor.Paid 50.00 at a yard sale. I had to replace the power cord.However the motor is running very slow.It has a MagneTek Century AC Motor on it.Could this be wired for 220, and if so can I switch it over? Motor:
Part # 8-182852-SP
Serial# BS3-01
Volt - 208-230 AMP 15
single phase 60HZ
HP - SPL (on compressor sticker says 6.5HP)
Thank you
J
(they make you pick a category....no electirc motor expert listed)
    President:
  • Coleman Master
  • 1,388 Answers
Century / Magnetek motors are used on many compressors but usually is an upgrade to have the option to easily switch from 110 to 220. Dewalt, Rol Air, Jenny, Emglo and others are considered high end compressors and come with switch for selecting voltage. One still must change the cord if selecting 220v setting. One thing in common is that 115v motors are never more than 2-3 HP because the amp draw for anything over 2hp is likely higher than 20 amps and would trip most common outlet breakers. You noted that your motor sticker lists 6.5 hp at 15 amp 220v so it could not work with 110v because it would draw over 30 amps and just not be practical. Magnetek motors are very good quality and most always state on sticker 110/220v and show wiring diagram for proper connection. Your compressor was most likely built to be stationary and be hardwired into an outlet/switchbox with heavy duty wiring or special cord to run such a high hp motor. You made a great buy however, because the motor alone lists for several hundered dollars alone. You could replace the motor with a 110v but you would loose the fast performance / recovery of that 6.5 hp motor. Like replacing a v8 engine with a 4 cyl. but expect to pull same load, not likely. Good luck with your purchase, and post again if you have other question.
Posted on Jul 11, 2010
Testimonial: "Thank you, I was starting to think so too.Just don't have the knowledge to say "your right".At this time it'd be easier to change motors. Thank you again. J"
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
I have an Coleman 4 in 1 compressor, model pmc8144. Picked it up at a yard sale, but no power cord. Where can I find one. Or did I waste $5.00?
Coleman sells parts through their web site. Failing that, hardware stores usually have cords, or radio shack if you need the 12 volt plug.
Sep 26, 2014 | Air Tools & Compressors
Coleman powermate compressor wont start. It has always ran fine. Went out and the tank has no pressure. Everything looks Ok, but it wont start. Doesnt even make a sound. There is power at the plug in. ...
Two main things to check are the motor circuit breaker and pressure switch. Without knowing your model number I don't know exactly where to tell you to look but somewhere on the electric motor, or plastic housing if it's remotely mounted, there should be a reset switch/button. They are usually red or white, sometimes black. Push it in and see if the motor works. If the breaker keeps popping off there is something making the motor work too hard like bad bearings in the motor or pump, piston/cylinder issues, etc. To check the pressure switch, unplug the cord or turn off the circuit breaker. Remove the cover on the pressure switch and find the wires from the cord and motor. You can jump them on the switch (black to black & white to white) or disconnect them and connect the two black wires together and two white wires together. Turn on the power and if the motor turns on it's the switch if not it may be that your motor is burnt up inside. Don't let it continue to run like this because it will overfill the tank to dangerous levels without the pressure switch wired in.
Jan 28, 2012 | Coleman Powermate 27 Gallon Air Compressor
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Air Tools & Compressors Logo
1,965 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
