Question about Shop Vac 201-12 Wet/Dry Vacuum
I purchase shop& vac vaccum item 215726 does it work on wet carpets in the basement
SOURCE: set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Posted on Jul 26, 2008
Buffalo12980
  • 625 Answers
SOURCE: shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
Posted on Aug 29, 2007
reddevil6
  • 1673 Answers
SOURCE: hoover steam vac
With the tank off, check to see if the rod in the handle is hitting the reservior asm,(this what the tank sits on). If it is, then the reservior asm. could be bad. If it isn't, then there is a problem inside the handle. Also make sure the filter at the bottom, has a red frame is clean. There also if there is a foam filter on the inside of the recovery tank lid, make sure it has a 1/4 in or so gap from the top.
Posted on Jun 21, 2008
  • 744 Answers
SOURCE: Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
Posted on May 16, 2009
kitt98
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Set up the shop vac to pick up water
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac 201-12 Wet/Dry Vacuum Logo
88 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
