Question about Sony Xplod XM-1652Z Car Audio Amplifier
Amplifier in home system - only one speaker working
HI
I am Sam. My Sony amplifier in the home theater, I am using it with a wireless microphone system. Only one speaker is working at any time. I checked the speaker. Both are OK. Only my amplifier is not outputting on both speakers. I will appreciate if you could help me to fix it. Thanks.
Sam
PS
It is the same problem with my other amplifier from Kenwood.
  • john wasson
    john wasson May 11, 2010
    check your inputs are the rca's only recieving signal from one channel?
  • 63 Answers
Is your wireless microphone only a mono signal? if so, thats why your only getting output on one channel regardless of amplifier used.
Posted on Jul 13, 2008
Is it possible to bridge 4 of the channels into 2 Monster MPA 5150 150 watts x 5 power amp
It would not be recommended, as the intent of the amplifier is to drive 5 individual speakers in a home theater setup. Bridging channels on the amp could cause damage and would definitely void your warranty. I would recommend simply not using two of the channels if you are looking to drive 3 speakers instead of 5.
Oct 26, 2015 | Car Audio & Video
High input amplifier installation
Hey guy! If you just bought that amplifier, whatever make and model, there should be instructions that came with it to hook it up to your radio or deck and any speakers you are to use!
Jan 15, 2013 | Sony Car Audio & Video
Hi im after some help coz driving w/o music is no fun. Just done a sterio system upgrade to my car using mid-high end sony xplod components ie 6x9s in the rear, xm4s amp, 6.5s in the doors new head unit...
Congratulations on your new audio system. I will give you 4 scenarios: 1st. From your head unit, use the Fader to separate the front speakers from the back. (only front speakers playing) now using the balance separate the left from the right so only one speaker is playing. If the sound becomes more bass filled then you have a phasing problems which could cause cut out (protection) issues. Do the same for the back speakers, BOTTOM LINE: make sure that your connections from amplifier to speakers are all correctly connected where they should be.You will know that your speakers are correctly connected when the bass is richer while both speakers are playing as opposed to more bass when only one is playing. 2nd. Your head unit RCA output is of a certain voltage (V) [signal strength]. (1.2V, 2V, 4V, 5V) Lets say that your head unit has a 4V output, To match this up with your amplifier you must adjust the gain control on your amplifier to be at the 4V position. If your voltage output does not match your input voltage and the signal in result that is being sent is too high for the settings on the amplifier, you will over voltage your amplifier making it distort then heat up and most likely start cutting out to protect it self. this could also potentialy damage your speakers. 3rd. Check that the speaker cables are not shorting on metal anywhere, that includes the speaker terminals not touching the frame of the location that they have been installed. 4th. The cable size you are using is not adequate for the power needs of your amp. hope this helps. dreamsystems
Feb 13, 2011 | Sony XM-4S Car Audio Amplifier
I cant figure out wh y my sony xplod 500w amp isnt working... i have everything connected but it still isnt wotking
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT POWERS UP FINE,THEN PROCEED TO CONNECT THE SPEAKERS FIRST AND SEE IF IT STILL POWERS UP FINE, THEN MOVE ON TO RECONNECT THE RCA INPUTS. AT THIS POINT YOU SHOULD HEAR MUSIC, IF NOT AND THE AMPLIFIER IS POWERED UP AND NOT GOING INTO PROTECTION, THEN YOU MAY HAVE AN INPUT PROBLEM FROM THE RADIO. IF THE AMPLIFIER FAILS TO POWER UP AT ALL AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. YOU CAN CHECK THE VOLTAGE TO THE REMOTE TERMINAL TO MAKE SURE THAT IT ABOVE 11 VOLTS, AS SOMETIMES A FAULTY REMOTE OUTPUT FROM THE RADIO CAN SOMETIME FAIL TO TURN AN AMPLIFIER ON. REMEMBER IN ANY CASE YOU ONLY HAVE AN AMPLIFIER, AN INPUT AND A SPEAKER. USE THIS PROCESS TO HELP YOU DETERMINE WHERE THE PROBLEM IS LOCATED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 16, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
I have a Panasonic twin subwoofer system. 7000w PMPO, 600w Rms multi amp system. With 2 main speakers, 2 woofers and 2 surrond speakers. The system is not working but the speakers are working properly.Is...
Yes it would be possible, acquire a home receiver or amplifier with either a crossover or an equalizer to filter out the high signals for the subs and is should work fine. Of course if the impedance does not match you do not want to blast the sound through them.
Mar 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
No power at speaker side
Is the power LED red or green?
If it's red, try reading through the following page to make sure that the amplifier is the fault and not somethig else in the system.
Amplifier in Protect - Troubleshooting
Jul 15, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car amplifiers
Generally, the 120v AC to 12v DC power supply costs more than a mains powered amplifier.
Also, many automotive amplifiers have poor speaker protection. If the amplifier fails, the speakers could be damaged. In some instances (older paper cone speakers with paper voice coil formers), the speakers could ignite.
Jun 08, 2008 | Jl Audio 500/1 Car Audio Amplifier
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
64 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
