Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus built-in dishwasher suddenly won't spray
Our diswasher (about 6 years old) just plain quit working this morning. The first few times I tried to start it this morning I could hear something filling with water, but the inside remained dry and the sprayer didn't spin. That happened twice. After that I didn't hear water anymore, but as I turn the knob through the various positions (start, short wash, rinse only, plate warmer) I hear the dishwasher making a clicking sound and kind of a "thump," but nothing happens. The circuit breaker hasn't been tripped. Nothing obvious is presenting itself.
The dishwasher has been occassionally leaking a bit from underneath during the drain cycle, but it isn't constant and has been happening for a few months (I know, I should've done something about that sooner!). I mention it in case it's related to this new problem.
I'm pretty unfamiliar with diswashers so any help would be welcome!
Model # is GSD3200J00BB
Micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Posted on Dec 09, 2010
HELLO MY GE Nautilus 24" Built-in Dishwasher sounds like it is working but there is no water spraying when the wASH cycle is iniciated any suggestions are appreciated
Hi, W/D here.
Check to see if the spray arms might be clogged. Look at each nozzle and slot. If you can remove them and clean over the sink. Back washing with the faucet, and opening the holes with a toothpick should free them up. That would be a good first step.
--Best regards--W/D--
Jan 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Nautilus diswasher is sending water out through the "overflow"? next to the sink, flooding the kitchen.
You must have a clog in the drain line. If it is ran to your garbage disposal then that is the first place to check.
Sep 17, 2010 | GE Nautilus 24" Built-in Dishwasher
Won't work...smells like somethings burning....6 yrs old
Unplug unit or turn breaker off. Under unit is a silver box, remove screws to check that all wires are attached securely to unit from plug, and confirm belt is intact.
Jul 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
Suds, overflowing out of dishwasher
Its old get a new one these are not designed to last more than yours did.
May 11, 2010 | GE Nautilus 24" Built-in Dishwasher
GE nautilus wont spray water. I ran it without the water on,think maybe i burned up the pump.
if you ran it for a long time you will need a new pump water keeps it cool and from sezing up
Jul 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Leaking from the front ?
Hello Kathy J...
It sounds as if you want reassurance that you should replace your dishwasher.. The costs associated with replacing the racks themselves and the gasket on the door ( depending on who does it) might justify the purchase of a replacement model.. Plus newer models are more energy efficient that the older ones.. 7 years of use is a fairly long time so you've gotten your money out of it... I always use this litmus test to validate the purchase.. if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense.. Very subjective indeed.. hope you make the right choice.. :-)
Sep 22, 2008 | GE Nautilus 24" Built-in Dishwasher
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
332 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
