Question about Daewoo DWC-121R Air Conditioner
I purchased and installed a DWC F0820CL 8,000 window unit. It only cools if the dial is turned just about all the way up. The top dial that is supposed to change the speed from hi, med, or low seems to be ineffective - hi or low sounds the same. I should remove it and return it but due to the difficulty for a 67 yr old woman to get it home and to my second floor and into the window I'm hoping you can give me a fix that I can do without having to return it.
2 Suggested Answers
  • 252 Answers
SOURCE: I have a daewood nano
Your clock board is bad. This happens when moisture from the outside gets into the electronic circuit board. This is common with your model of AC.
Posted on Aug 19, 2010
Can freon be added to a window are conditioner?
This type of unit don't need much Freon but if it known leak yes fit it and add Freon as factory spec
Aug 09, 2014 | Daewoo DWC-0820FCL Window Air Conditioner...
How doest it drain on air conditioner 25379081
most window units use the condensation to help cool the condensor. some days little to any drainage. a slinger ring on outsde blade side throws water on coil and evaporates.
Jun 29, 2014 | Kenmore 8,000 Btu Room Air Conditioner...
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
There is no cold air from DAEWOO Air conditioner.
this could be a multitude of things: you said it worked when installed,window unit right anything punture the coil exposed to outside, if so freon leak no freon no cool Secondly is the filter dirty these unit needs to breath to work if its dirty it wont cool. switches in the same position turn them back and forth a few times see if that helps. always look for the obvious first and work your way back from there. If this is the first time you ran it since purchase was anything punctured on install if not maybe it was a lemon take it back if possible if not charging these things are a pain, it will need taps on the high and low side this should only be accomplished by a licensed professional and could be costly. give this a try and goodluck
Jul 11, 2010 | Daewoo DWC-056CL Air Conditioner
I purchased 2 0520RLE airconditioners at cosco one has no hardwar
Contact the manufacturer explain your problem and they should send you the hardware you require.
Jun 12, 2010 | Daewoo DWC-052C Air Conditioner
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Daewoo (DWC-056CL) Air Conditioner
You don't have to remove the polystyrene that is inside the unit. It is part of the construction of the unit. It is part of the molded construction.
Jul 02, 2008 | Daewoo DWC-056CL Air Conditioner
Daewoo DWC-121R Air Conditioner Logo
66 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
