Question about Sherwood RX-5502 Receiver
Sherwood receiver automatically going to standby
I have a Sherwood RX5502 brand new. It was installed by a dealer. When I turn up the volume on the receiver or when I add rooms to the receiver it goes to standby from AUX input. I think it may be getting hot and kicking out as a safety. Does this unit have a cooling fan? If so I do not hear mine running. I do not know what the total wattge is on the entire system but I am guessing that possibly the wattage required to run the speakers is more that the unit will output (causing an overload) and subsequent kickout into standby. Any help on this would be greatly appreciated. My confidence in my dealer and device is at an alltime low or I would call him with this problem.
  • 6,826 Answers
You might have a point there as far as it switching to Standby from AUX input.
Are any fuses, if there are any, blowing?
Caution regarding installation
Note : For heat dispersal, do not install this unit in a confined space such as a bookcase or similar enclosure.
:CAUTION
WARNING
Do not block ventilation openings or stack other equipment on the top.
I did not read that any cooling fan exists on this unit, but that doesn't mean there isn't one.
The unit consumes the following:
• Power consumption ........................................................................................................................................ 3.3 A
if P=VI then Power = 110V*3.3A= 363 Watts of power output
Posted on Jul 11, 2010
My sherwood rx 4109 has no sound what do i do
Pull the sherwood power cord from the wall for 20 minutes. On the back of sherwood, check all cables and make sure they are in the correct places. Check speaker wires and make sure they are connected. 1)After 20 minutes, turn power on to sherwood. 2) select an input (radio, cd, etc.) 3) Push play. 4) Turn volume to desired level.
Feb 07, 2015 | Sherwood Audio Players & Recorders
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
Schematics rx5502 sherwood
All you can do is search the Internet for such a service manual. I find them at Hi Fi Engine or Electro Tanya on occasion. Stereomanuals dot come will have good paper manuals but they are not free.
Jan 29, 2014 | Pioneer Audio Players & Recorders
Sherwood
does a code pop up like f20 or just any code
Mar 20, 2013 | Audio Players & Recorders
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
Keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
May 23, 2010 | Sherwood RX-4109
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Sherwood RX-5502 Receiver Logo
226 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
