Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
I have a clarke air compressor model no SE14A150 4HP.ineed to get some parts.it has no pressure switch,it keeps running until i unplug it,i have no manual either?
  • 21 Answers
SOURCE: clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Posted on Dec 26, 2008
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 98 Answers
SOURCE: where would I find a manual for a clark air
Needs new valves
Posted on Jul 21, 2009
falspet
  • 438 Answers
SOURCE: clarke shhh air compressor model 3/24 that is not
the rings on the compressor piston may be leaking, also check the one way read valves are in good condition, to verify a ring problem you can inject a light oil into the air intake like wd-40 wile trying to run up to pressure, if the pressure increases doing this they will need replacing and honing of the cylinder bore is required, if not the read valves are faulty and need to be replaced
Good Luck
Posted on Jan 28, 2010
roniecon
  • 6927 Answers
SOURCE: clarke air comp. parts
www.aavolyn.com/it070002.htm. try this on line
Posted on Jun 23, 2010
Clark air compressor parts
Most compressor shops will stock the part
Aug 17, 2014 | Air Tools & Compressors
?? LOCATE A MANUAL/PARTS DIAGRAM FOR CLARKE AIR COOMPRESSOR
You didn't state your model number but the only place I could find that has manuals for Clark air compressors is Clark Power Porducts UK at: www.clarkeservice.co.uk/product_manuals/air_compressors.shtml. Usually if you have an air leak at the pressure switch when the tank is full and after the motor shuts off it is indicative of a stuck or broken tank check valve. Sometimes they can be cleaned and will work for a while but more often than not they have to be replaced.
Sep 06, 2012 | Clarke Air Tools & Compressors
Looking for parts for a Clarke air compressor
try machine mart in uk they are main agents for clarke machines over here
Jul 06, 2012 | Clarke Air Tools & Compressors
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
STARTS AND RUNS FOR 30 SECONDS THEN SHUTS OFF, STARTS AND RUNS FOR A COUPLE SECONDS KEEPS DOING THIS. I SUSPECT IT HAS A THERMAL SWITCH. WHERE IS IT? CAN I WIRE AROUND IT?
Hi
Yes I think you may be right, it could quite well the thermal switch,"pressure controlled on/off"switch and is not properly set up, minimum and maximum stop/start.
If what I see in the photo, the pressure switch is beside the top tank with a pressure gauge on it, and the electrical supply should feed into/from it.
Hope this gives you a little food for thought, and hope that it is a little helpful
Cheers
John
Jul 19, 2011 | Clarke Power Products AC2002A 2 Hp Air...
Adjust cut out switch on Clarke AC2525 Air Compressor
hi mate on the pressure switch in the middle there will be a screw unscrew it and pull the cover off and inside you will see a screw or a bolt it is straight on top you cant miss it it will have a +/- on the left or right of it unscrew to decrease pressure screw in to increase pressure but unplug the machine before you do
Aug 27, 2009 | Clarke Power Products AC2002A 2 Hp Air...
I broke the red on off switch, on my preasure switch
IF YOUR TALKING ABOUT THE ON/OFF SWITCH ON YOUR PRESSURE SWITCH JUST REPLACE THE PRESSURE SWITCH WITH A NEW ONE FROM ANYWHERE - ONE THAT HAS THE SWITCH ON THE SIDE. TAKE YOUR OLD PRESSURE SWITCH WITH YOU TO MATCH IT. IF IT HAS SOME FANCY SWITCH MADE INTO THE COVER YOU CAN ADD THE PRESSURE SWITCH WITH THE SWITCH ON THE SIDE OR JUST BYPASS IT ALL TOGETHER. IT DOESNT EVEN HAVE TO BE THERE, THE COMPRESSOR WILL SHUT OFF AT CUTOFF PSI ANYWAY AND YOU COULD UNPLUG IT TO KEEP IT FROM RUNNING WHEN YOUR NOT USING IT. THE PRESSURE SWITCH W/ ON/OFF ON THE SIDE IS VERY AVAILABLE. HOPE THIS HELPS, JODY
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
Dec 09, 2008 | Air Tools & Compressors
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
148 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
